Author Topic: ram mount for 997 ?  (Read 24285 times)
Offline lester547
  • Unit(s): 997 & 788
  • Accessories: INTERLINK
ram mount for 997 ?
« on: December 09, 2009, 04:39:09 PM »
I'm a proud new owner of a 997 and 788. What size ram mount is everyone using for the 997 on your consoles? any recommendations?
Offline reelman
  • Find the bass, fool the bass, free the bass...
    • LouMissBass
  • Unit(s): 898, 788
  • Software: 5.5 I guess
  • Accessories: 2 ducers; 2g SD cards; 8g Extreme III
Re: ram mount for 997 ?
« Reply #1 on: December 09, 2009, 04:43:10 PM »
Do NOT use the smallest one...unless you have a 50hp engine or less...been there, the unit folds back easily over 40mph...whatever the next one up is...use that one...and tighten is very well...now I can do 70mph without the unit folding back..
Offline lester547
« Reply #2 on: December 09, 2009, 05:16:49 PM »
That's what I'm afraid of. I was told the ram 111U will work fine. But ram mount website says to use the 111-D, or something like that. It is the big big one for $100. Just wondering if anyone uses the 111U. It has the 6.25"+ 2" plate.
Offline wizzo86
  • diving in phillapenes
« Reply #3 on: December 09, 2009, 07:14:19 PM »
Welcome to the forum.
Offline rwindis
  • Unit(s): 997 SI
  • Software: none
  • Accessories: none
« Reply #4 on: December 15, 2009, 12:36:18 PM »
I also just received a 997 and am looking for the best mount.  The ram I think will work the Best for me is a swung arm style.  But these still have the same smaller mounting plate around 6.25".   If you have any luck let me know and I'll do the same.
Offline lester547
« Reply #5 on: December 22, 2009, 11:36:23 AM »
well i just bought the 111U, so i will know by this weekend.
Offline lester547
« Reply #6 on: December 26, 2009, 09:57:51 PM »
just installed my 997 on the 111U with the 1.5 balls. its pretty big and holds good. and only $40 or so bucks, compared to the $100 one.
Offline Fisherman1850
  • Elbow Lake Mn
  • Unit(s): 998C SI
« Reply #7 on: April 04, 2010, 10:12:37 AM »
My boat came with a RAM 111u that had a smaller sonar on it.  I removed the old sonar and reused the same mount for my 998c and it is working great!
Ram can be confusing with their model numbers.  This is the mount that has the 6.25" plate and the 1.5" ball.
Mark
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #8 on: April 04, 2010, 11:28:01 AM »
I have two ram mounts 1.5 inch ball for my 997 but i don't care for the small plate
so i ordered a 3 by 11 inch plate for the 997 got it on line. I have a 2.25 inch ram for the bigger
unit i will buy in the future not sure now what i will put on the console
Offline blharr4400
  • Unit(s): 788Ci Combo 1197C SI COMBO
  • Software: 4.78 and 4.75
  • Accessories: Weathersense, Interlink
« Reply #9 on: April 05, 2010, 10:26:34 PM »
I am speaking from expecience what an 1197 unit but I think it more then applies for all you guys.  I have the biggest ram mount that is offerd, the 100 dollar one.  It has more then enough "lenght" to get the big 1197 away from the consoule for mounting and when tightened down I run 65 mphs across the lake and it has never moved.  Just my two cents.
Ben
I wont always catch fish but they are never going to sleep through me being there!!!
Offline Llunker
  • Team Llunker
  • Team Llunker
    • Ultimate Lunker Fishing Forum
  • Unit(s): 997c SI
  • Software: 4.75
  • Accessories: SI with in-hull transducer as well
« Reply #10 on: April 09, 2010, 07:35:14 AM »
Hey,   I use the 2.25" ball here look at that this photo--RAM-D-111U--i got mine for like $60 somewhere like an ebay.
Hope this photos helps--i got the long shaft so i can turn it towards the bow and see my pretty 997 from the front.
El Grande Lures Field Staff
Offline bobn
  • Unit(s): 997 csi
« Reply #11 on: April 09, 2010, 09:16:02 AM »
I have a 997 mounted on a 1.5 inch ram mount.  In my experience running thru large waves it will not keep the unit fixed no matter how tight  the mount.   If  you want a rock solid mount for rough water go for the larger 2.25 inch mount.
Offline tmljunkmail
« Reply #12 on: April 12, 2010, 03:09:39 PM »
You should use the largest ball they have for sure.....why take the chance on a $2000 unit.
If you want to spice it up.....you can do what I did......
Mount a low profile downrigger pedestal that pivots and then mount the ram ball to that.  This way with a quick pull of the pin your can swivel the whole unit around to be visible from the bow.  This is WAY easier than dealing with the ram ever time you want to twist it around.
Offline majflyboy
  • Unit(s): 998 and 788
  • Software: 4.85
  • Accessories: InterLink
« Reply #13 on: April 17, 2010, 04:17:23 PM »
tmljunkmail, can you post a picture of your complete set-up?  I have a new 998 and am looking for the "perfect" mounting method.  Thanks.
Offline Kickerfish641
  • Unit(s): 1197 NVB-998 NVB
  • Software: 4.75
« Reply #14 on: April 25, 2010, 04:44:10 PM »
In regards to ram mounts, the "letter" in the model number represents the ball size, farther in alphabet the letter = bigger the ball size.  try Ebay,There is an "Ebay store" that has the biggest mount (2.25" ball) for $86.00 including shipping
Last post March 29, 2010, 10:05:38 AM
Last post April 18, 2010, 05:25:18 PM
Last post April 22, 2010, 07:40:19 AM
Last post June 14, 2010, 04:22:49 PM
by ericbev
Last post August 10, 2010, 11:44:44 PM
by Doug Johnston
Last post September 01, 2010, 12:37:02 PM
by stoporilshoot
Last post September 02, 2010, 02:45:53 AM
by stoporilshoot
Last post December 21, 2015, 11:04:14 AM
by Archie
