Author Topic: gps and speed unconected  (Read 4466 times)
Offline bwdjohnson
  • Unit(s): 587ci HD di
  • Accessories: gps
« on: January 05, 2013, 05:24:13 PM »
i have a 587ci HD di and it says the gps and speed are unconected
Re: gps and speed unconected
« Reply #1 on: January 05, 2013, 05:43:44 PM »
Check all connections and power supply voltage..
Is this a new or used unit..
Has it worked before....
« Last Edit: January 05, 2013, 05:44:45 PM by sonar2000 »
Offline bwdjohnson
  • Accessories: gps
« Reply #2 on: January 05, 2013, 05:46:56 PM »
i know its not the conections but could be the power supply/conection to power supply
Offline bwdjohnson
  • Accessories: gps
« Reply #3 on: January 05, 2013, 05:48:26 PM »
it is fairly new 2/3 months old and it has worked until today
« Reply #4 on: January 05, 2013, 05:51:24 PM »
OK check the power supply.  good fresh charged battery or known good converter... Make sure the amperage is good if a converter...
Let us know..
Offline navionic
« Reply #5 on: January 06, 2013, 05:56:46 AM »
This is a marriage unit. Power is not to blame. Try to change the firmware. If not help back to the factory.
« Reply #6 on: January 09, 2013, 02:14:00 PM »
“marriage unit” ?
bwdjohnson,
Are you using this unit outside?
If the power connections check good you will need to call the Humminbird Customer Resource folks and see about getting your 587ci HD DI unit in to be serviced. 1-800-633-1468
Offline navionic
« Reply #7 on: January 09, 2013, 03:25:43 PM »
“marriage unit” ?
Likely faulty internal GPS receiver. At home, it is not repaired. Already experienced this only in the other device.
Last post January 17, 2010, 12:31:04 AM
Last post June 29, 2010, 10:21:05 AM
Last post June 26, 2012, 07:08:27 PM
Last post August 06, 2012, 02:41:57 PM
by ScottMN
Last post December 31, 2012, 10:47:56 AM
Last post June 17, 2016, 04:16:13 PM
by Gimp
