Author Topic: SI and the effect of chart speed and boat speed  (Read 13180 times)
Offline tikka-t3
  • Unit(s): 898csi
  • Software: 5.5
  • Accessories: none
« on: May 30, 2011, 10:14:40 PM »
I have read that slowing down the chart speed will increase the amount of structure detail shown on the SI display.
Is there a general rule of thumb to use between boat speed and chart speed or does it not matter?
« Last Edit: May 30, 2011, 10:21:04 PM by tikka-t3 »
Offline Double Digit
  • Unit(s): 998 c si...Navionics Platinum +
  • Software: 6.180
Re: SI and the effect of chart speed and boat speed
« Reply #1 on: May 30, 2011, 10:38:44 PM »
I have read on this forum that you should match your chart speed with the speed of your boat.I seem to get the best images when I'm going between 3 and 4 MPH.So i will either set my chart speed to 3 or 4.....I'm far from an expert but this has worked for me... ;D
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: June 01, 2011, 12:24:59 AM »
Boat speed = chart speed is a good place to start. ( @ 3,4 or 5 MPH range ) Adjust each a little at a time to see what works for you.
It is also important to travel in a straight line.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #3 on: June 03, 2011, 08:41:51 AM »
Check here:
http://forums.sideimagingsoft.com/index.php?topic=242.0
Hope it (still) helps!
Regards / Harry
YES,......
WE SCAN!
Chart Speed
Started by Carl 798c SI
Last post July 11, 2010, 05:16:58 PM
Last post July 29, 2010, 03:55:06 AM
by gobio
Last post October 31, 2010, 09:52:32 PM
Last post January 16, 2012, 04:18:09 PM
Last post August 06, 2012, 02:41:57 PM
by ScottMN
Last post April 17, 2020, 05:13:39 PM
by Philip Brown
Last post August 05, 2015, 08:55:35 PM
