Author Topic: ALL SI Models - Sonar and DI Speed Adjustment using GPS Speed  (Read 8345 times)
Offline n_texas_basser
  • Unit(s): 1198, 998, 788
  • Accessories: 2 GR-50's, Interlink, SI
« on: August 05, 2012, 09:33:47 AM »
Model:
ALL SI Models
Suggested Upgrade:
Explanation:
Since it generally is best to match your sonar, DI, SI speeds with the speed of your boat when idling and marking structure and fish, I do so; however, when going on plane and shooting thru the hull, to ensure you still get depth readings, you manually have to increase the speed. Why not have the option to increase the sonar/di speeds to max once your GPS reads a configured speed? Very similar to the zoom out on the chart feature once you hit a certain speed. This would be very helpful, mostly to ensure once you get off plane and continue to search, that you don't forget your sonar/di speed needs to be lowered.
Added in Software Version:
Comments on Update:
Offline ScottMN
  • Unit(s): 1198c SI..597 HD DI..30+ Green Boxes
  • Accessories: 101-Terrova/iPilot/iLink/LakeMaster Maps
Re: ALL SI Models - Sonar and DI Speed Adjustment using GPS Speed
« Reply #1 on: August 06, 2012, 02:41:57 PM »
Agree
How many cables do you own for gadgets?
Last post March 22, 2012, 02:59:42 PM
by Gattlin
Last post May 27, 2011, 04:36:41 PM
by offroad
Last post July 31, 2012, 03:33:50 PM
by Jim Jack
Last post April 17, 2020, 05:13:39 PM
by Philip Brown
Last post September 04, 2013, 08:31:28 AM
Last post April 12, 2014, 11:39:41 AM
by mlhare
