Author Topic: What 997csi data can the 385ci make use of  (Read 8077 times)
Offline benamen
  • Unit(s): 997C SI
  • Software: 4.75
  • Accessories: none
« on: December 27, 2012, 12:15:26 AM »
I have mapped out quite an area on a particular lake in the last couple years. Now I would like to transfer the waypoints and depth data from the 997csi to use in the 385ci to use while ice fishing. Which files would be needed to be transferred to a sd card to accomplish this?
Thanks,
Ben
Re: What 997csi data can the 385ci make use of
« Reply #1 on: December 27, 2012, 10:09:04 AM »
I would think if the unit's are compatible, and you
have a card slot on the 385ci, then just put in your
SD card from the 997, and the NAV data should
load into your 385ci.
« Reply #2 on: December 27, 2012, 12:15:28 PM »
+1
This will transfer all the waypoints, routes and tracks that you have in your 997c Si unit.  Just make sure that you do not have more waypoints, routes and tracks than your 385ci unit can handle as it does not have the same memory capacity that the 997 unit does.
Last post October 28, 2009, 07:44:35 PM
Last post February 28, 2010, 07:06:58 PM
Last post April 16, 2011, 11:39:06 AM
by fishbone
Last post September 07, 2011, 09:09:30 PM
Last post January 29, 2013, 10:41:01 AM
Last post September 16, 2014, 08:01:04 AM
Last post October 09, 2014, 02:21:15 PM
Last post September 08, 2015, 05:07:42 PM
by Mark Saikaley
