Author Topic: Thru hull si transducer on aluminum keel?  (Read 21236 times)
Offline Rotus623
  • Software: 6.49
« on: December 19, 2012, 10:52:25 PM »
Hey guys I have a 998c si. I was looking at the transom and the skeg is going to be in the way of the ducer if I mount it on the transom. Have any of you guys mounted the plastic thru hull si ducer in the keel of the back end of any aluminum boats? The dead rise is high enough that if I mount it directly in the center my si will have plenty of clearance. I posted a pic of my Starcraft, do you guys think it will be a good idea to trade my transom mount for the thru hull? It would be a crime to drill through my precious aluminum if it is going to be less than ideal. I'd like to avoid mounting two transducers because it is expensive and doesn't look good in my opinion. http://i803.photobucket.com/albums/yy317/rotus623/Boat%20Restoration/P4291144.jpg
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Thru hull si transducer on aluminum keel?
« Reply #1 on: December 21, 2012, 12:11:53 AM »
I would not be drilling a hole in my aluminum boat.
Scroll down to the bottom of this post to see how I mounted my 998 transducer on a aluminum boat.
http://forums.sideimagingsoft.com/index.php?topic=4764.msg29554;topicseen#new
If you have power T/T, just slightly raising the motor should get you clearance for the SI beam.
Offline Rotus623
  • Software: 6.49
« Reply #2 on: December 21, 2012, 09:32:01 AM »
While that is innovative, the skeg of my motor will still be in the way if I did that. That is my main concern, but I agree drilling a hole in aluminum is less than ideal.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: December 21, 2012, 11:30:37 PM »
How much clearance do you have between the transom and the front of the lower unit on the outboard?
Offline reddog
    • My pictures
  • Accessories: Ipilot Link
« Reply #4 on: December 22, 2012, 08:51:02 AM »
Mount it where the two white spots are to the left of where it is shown now.
   What have you  got to lose?  A little time?
Can you take a side shot photo of your transom/motor.
There are thousands of transom mounted installations, Im having a hard time seeing why yours will hit the motor..
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: December 22, 2012, 05:49:09 PM »
Mine was originally mounted as reddog suggest.
Normally I have one or two people on-board and the port/starboard level was OK.
But with a third person, the transducer was tilted enough to affect the image.
So I decided to make something that I could adjust to any situation I had.
My imagination took over and that is what I ended up with.
You don't have to step off the deep end like I did; just know you have options.
Offline Rotus623
  • Software: 6.49
« Reply #6 on: December 22, 2012, 10:26:11 PM »
Thanks mike.  And reddog thanks for the input. I heard that I need about 4.5" between the transom and the lower unit. Does that sound right?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: December 22, 2012, 10:36:36 PM »
I think the preferred distance is 6 inches.
The side beam width is about 4 inches.
Do you have power tilt/trim?
Offline Rotus623
  • Software: 6.49
« Reply #8 on: December 24, 2012, 09:29:50 AM »
No power TnT. ThAt is why there is a placement issue...
« Reply #9 on: December 24, 2012, 09:39:39 AM »
You might consider mounting your transducer on a verticle shaft (like the shaft on a portable trolling motor) and use a Ray mounting bracket for the transducer. That way you can position it where you want and tilt it accordingly to the way people are sitting (fishing) in your boat..
I will get a picture of ours and post here..
« Reply #10 on: December 24, 2012, 09:47:30 AM »
Here is a picture of our portable mount. You can tilt it forward or aft .....or left to right...
Offline Rotus623
  • Software: 6.49
« Reply #11 on: December 24, 2012, 02:48:09 PM »
That's pretty innovative 2000. Does it hold still when you are under way?
« Reply #12 on: December 24, 2012, 03:08:50 PM »
Yes, but we dont use it at speed. Most of the time 2 to 5. If we go to plane speed we raise it up. The whole setup does not cost all that much and I have not been on a boat yet that we could not put it on.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #13 on: December 24, 2012, 04:01:00 PM »
haha. looks like a BPS Pond Prowler transom trolling motor ..or what's left of it.
Is the shaft big enough for the connector to feed through the length?
« Last Edit: December 24, 2012, 04:02:11 PM by LocDown »
« Reply #14 on: December 24, 2012, 05:27:17 PM »
Yes the connector will fit thru the shaft.  We left it on the outside. the shaft and mount are a standard replacement parts available thru any boat dealer. We ordered the Ray bracket for the transducer to make it easy to put on.
Works well as a portable system and as I said it fits almost any boat.
Offline Rotus623
  • Software: 6.49
« Reply #15 on: December 25, 2012, 01:10:10 PM »
So I guess you just don't use a sounder at higher speeds?
« Reply #16 on: December 25, 2012, 05:51:41 PM »
This arrangement is used portable in search and recovery, and generally on someones elses boat.. For speed soundings we will rely on what ever the boat has installed.
Our boat does have sonar for speed but it is not the HB brand...
Offline reddog
    • My pictures
« Reply #17 on: December 25, 2012, 11:52:32 PM »
Rotus,
Post  a side angle photo of your boat and motor..please..
It cannot be that different than any other tin boat..   If the motor has no tilt/trim, then there has to be adjustment holes/pin to adjust the pitch of the motor..  If its pinned down to the transom, I cant imagine that is your best performance option..
Offline Rotus623
  • Software: 6.49
« Reply #18 on: December 26, 2012, 11:10:19 PM »
Red oddly if it is just me and one other than the boat porpoises at half throttle or over, unless the motor is trimmed as shown. If I have three people than I canoe the motor up one or two pins without porpoising. I was trying to get a new prop but can not get my tiny tach to give me a good WOT run. What a pain.....
Offline reddog
    • My pictures
« Reply #19 on: December 27, 2012, 09:51:11 AM »
Rotus,
Give Ricky a email at www.brainerdprops.com
Tell him what you currently have for boat, motor and prop and he can make a recommendation.
What you are doing now, is basically driving the nose of the boat into the water to eliminate the porpoising, which also puts a large amount of drag on the boat, leading to poor performance..
They also have a 14 day trial period to try props, (if they have your prop in stock)
He is a master at figuring this stuff out.
« Reply #20 on: December 27, 2012, 10:03:42 AM »
As Reddog had requested, is it possible to take a  couple of pictures of your boat. The transom for the transducer mounting, the boat inside for loading and weight..
Pictures help us see exactly your setup or condition..
Thanks, Chuck
Last post March 31, 2010, 10:53:54 PM
by diver651
Last post April 14, 2010, 02:45:32 PM
Last post March 11, 2011, 11:47:15 PM
by reddog
Last post May 27, 2012, 09:37:02 PM
by choc_e
Last post April 26, 2013, 02:28:50 PM
by snooktarpon
Last post June 24, 2013, 12:32:03 PM
by 4d-rock
Last post May 05, 2014, 04:07:57 PM
Last post September 03, 2014, 12:11:17 PM
by Free2Fish
