Author Topic: 998c SI and in hull transducer  (Read 14411 times)
Offline choc_e
  • Unit(s): 997si
« on: May 15, 2012, 05:13:25 AM »
Hi All,
Just wondering which in hull transducer will work witht the 998c SI? I used the XP 9 20 T and it isn't working. I realise the side imaging won't work with one of these but has anyone got one working for 2d imaging?
I installed it as directed and it just reads 1 foot 6, is it not compatible? Should I have used the XP 9 QB 90T?
Ryan
Offline choc_e
  • Unit(s): 997si
Re: 998c SI and in hull transducer
« Reply #1 on: May 18, 2012, 06:23:07 PM »
anyone?
Offline George
  • Software: Always up todate
« Reply #2 on: May 18, 2012, 07:12:04 PM »
choc_e
I have the same transducer, but a different Humminbird (728).  I looked up XP 9 20 T transducer and it appears to be compatible with almost everything but 998 is not mentioned this does not make sense since the 1197 AND 1198 are compatible.  I would suggest that you contact Humminbird customer service to confirm whether or not it is compatible.
George
Offline Blackwaterkatz
  • Unit(s): 797c si / 998c si / 1198
  • Software: 5.450 / 5.700
  • Accessories: weathersense
« Reply #3 on: May 18, 2012, 08:40:05 PM »
With my 998, I used the XP 9 20 (no temp) transducer to mount in the hull, and the AS SIDB Y splitter cable.  It works very well, at all speeds.  You don't need the temp, as that is acquired through the hdsi ducer.
The XP 9 20 T should work as well.  I assume you did use the splitter cable.  If it isn't working, either the transducer is bad, or perhaps when you epoxied it in place, there were some air bubbles either in the epoxy or the hull itself.  Hope you get it working.
« Last Edit: May 18, 2012, 08:41:43 PM by Blackwaterkatz »
Tommy in Lowcountry S.C.
Offline choc_e
  • Unit(s): 997si
« Reply #4 on: May 20, 2012, 06:36:05 AM »
thanks, I'm not using the y cable. might try a factory rest on the next trip. Failing that I think I will get a transom mount.
« Reply #5 on: May 21, 2012, 01:41:52 PM »
choc_e,
Did you test the transducer location before epoxying the transducer in place?
Have you tried using your 998c Si unit with the standard XHS-9-HDSi-180-T transducer that comes in the box?
Offline choc_e
  • Unit(s): 997si
« Reply #6 on: May 27, 2012, 09:37:02 PM »
I didn't test it first because I was short of time and this is a common position for the transducer in this boat. I have tried the transducer that came with the unit and works fine.
Are there any other settings Greg?
Last post March 31, 2010, 10:53:54 PM
by diver651
Last post April 14, 2010, 02:45:32 PM
Last post October 30, 2012, 01:51:28 PM
Last post December 27, 2012, 10:03:42 AM
Last post January 08, 2014, 02:54:18 PM
by hgv
Last post January 14, 2014, 02:47:55 PM
by Rotus623
Last post July 21, 2014, 04:13:30 PM
by TXAG DAC
Last post September 12, 2014, 09:58:18 AM
