Author Topic: Transducer mounting help  (Read 10525 times)
Offline Dblount
  • Unit(s): 798si
« on: October 28, 2012, 03:30:24 AM »
I am trying to mount my transducer on an old bass  boat and it doesnt have the clearance between the transom and the motor, only about 4 inches. Is there any other way I could mount it and get it to work? I have a 798si
Offline George
  • Software: Always up todate
Re: Transducer mounting help
« Reply #1 on: October 28, 2012, 06:23:53 AM »
Dblount
It would help if you could post a picture of the conditions, it might help us to help you.
Offline Dblount
  • Unit(s): 798si
« Reply #2 on: October 28, 2012, 01:40:50 PM »
I figured it would, the boat is at my lake house a couple hours away, so I can't get a picture right now. It seems to me that I really just need to put a jack plate on it, so there will be sufficiant clearance. Also it doesn't have tilt or trim to get the motor out of the way when scanning.
Offline George
« Reply #3 on: October 28, 2012, 02:00:01 PM »
Dblount
If you cannot get the transducer to see past the motor, the other choice is to use 2 transducers for side imaging.  I believe there is some information on this site about hooking up 2 transducers.
I am sure that you will hear from others on this site, hopefully with good suggestions.
Since you do not have pictures, can you give a description of the boat's transom and the size of the motor?
« Reply #4 on: October 29, 2012, 11:11:00 AM »
Without tilt/trim your only options are either to add a jackplate to move the motor back out of the way, add a tilt/trim or add a second Si transducer and an AS-Si-LR-Y transducer.
Offline Dblount
  • Unit(s): 798si
Re: Transducer mounting help pics
« Reply #5 on: November 12, 2012, 02:24:04 AM »
Here is a pic of the transducer. the images I was getting with it setup like this were really grainy. I probably need a lot of fine running if this transducer looks like it is setup ok. They were also a lot of black in the left side image.
Offline Dblount
  • Unit(s): 798si
« Reply #6 on: November 12, 2012, 02:26:06 AM »
Pic
Offline Rüdiger
« Reply #7 on: November 12, 2012, 04:49:57 AM »
Hi Dblount
The assembly area looks good, but could be problems with air bubbles.
mvh
Rüdiger
Finding is better than losing
Offline Dblount
  • Unit(s): 798si
« Reply #8 on: November 12, 2012, 05:24:45 AM »
Is there anything I could do to help with that? I am going to try to get sine screen shit next week I didn't have a ad card with me this week. It seemed to work better going a little faster, 6 mph compared to 3 or 4. I was adjusting my chart speed to match that. I was going by known structure and wasn't really able to make it out.
« Reply #9 on: November 12, 2012, 12:45:04 PM »
My guess is that it could be air bubbles as well.  I see that you got creative and flipped the mount upside down to get it to fit under the step on your boat.  Ideally the transducer would be flush or lower than the bottom of your hull but I see that you cannot do that without damaging the transducer with the roller on the trailer when you load/unload your boat.  Without going to a jackplate or a two-Si transducer system as mentioned before, this may be the best that you can do – but let’s see some screen snapshots first.
Offline Dblount
  • Unit(s): 798si
« Reply #10 on: November 12, 2012, 04:12:00 PM »
Thanks for the help I will get some snap shots this week and post them. I have been so excited about this unit since I got it, just ready for it perform like the ones I see on here.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #11 on: November 13, 2012, 06:48:16 PM »
Maybe you could push the bow hook winch thingy on the trailer back some so the back of the boat is hanging off the back of the trailer instead of inside it.
Offline Dblount
  • Unit(s): 798si
« Reply #12 on: November 14, 2012, 12:31:57 AM »
Yea I'm going to mess with it this weekend. And see what I can do. Thanks for the idea.
by jgcox6
Last post December 30, 2013, 10:52:41 PM
Last post January 30, 2014, 01:29:19 PM
Last post November 25, 2014, 05:13:59 AM
by jabsy
Last post January 21, 2015, 12:08:28 AM
Last post August 23, 2016, 10:05:55 AM
Last post September 27, 2016, 03:40:27 PM
by Mukwah
