Author Topic: My GPS stopped working  (Read 12281 times)
Offline e1035
  • Unit(s): 998c si
  • Software: factory
« on: August 21, 2012, 11:46:00 PM »
I have a 998 I purchased in March 2012 and the other day the GPS stopped working. Worked fine the previous day. Unit states GPS not connected. I checked all connections, rebooted, and reset to factory defaults but nothing solved problem. Unit cables stayed connected between when it worked and stopped working. I am going to take a close look at the puck and the pigtail on unit end, and will also check battery. After reading alot of posts, seems like a fairly frequent issue.
Offline Roddy
  • Scan,scan and rescan
Re: My GPS stopped working
« Reply #1 on: August 22, 2012, 12:39:56 AM »
e1035, Try cleaning the plug ends and check the pins.
If that does not work call Humminbird to get a replacement.
Roddy
Scan,Scan and Rescan Roddy
Offline e1035
  • Unit(s): 998c si
  • Software: factory
« Reply #2 on: August 22, 2012, 05:46:25 PM »
The reason my GPS quit on me was the GR50 external antenna had moisture inside it. This caused corrosion on the 4 pins where the wiring connects. I called Humminbird right away and they are sending a new GR50. Lucky for me it was still under the 1 year warranty period. I was told the puck is on backorder so it might take up to a couple weeks to be up and running again.
Last post October 10, 2009, 12:04:03 PM
Last post June 14, 2012, 07:01:39 PM
by ctf58
Last post July 10, 2013, 08:06:35 AM
Last post November 19, 2014, 12:42:02 PM
by rnormanr
Last post October 31, 2015, 11:48:48 PM
by lake anna george
Last post July 03, 2017, 09:42:29 PM
Last post December 17, 2020, 09:15:06 PM
by Planokeith
Last post July 11, 2019, 10:17:11 PM
