Author Topic: 898c si can't get map card to work  (Read 15096 times)
Offline robbie48
  • Unit(s): 898c si
  • Software: ??
  • Accessories: gps
« on: August 15, 2012, 09:41:09 PM »
when i install navionics map card in my 898 it says loading and never does anything else.it is a card i've had for a while.used in matrix 97works great in 97???
Re: 898c si can't get map card to work
« Reply #1 on: August 16, 2012, 08:50:58 AM »
It may have loaded, but you might not see anything different, unless
you are on a lake/river/reservoir that's on that particular map.
If you're sitting at home looking at your unit, and the nearest
water on that map is 200 miles from you, then you won't see
anything different.
On your Humminbird map screen, you should be able to scroll
to one of the waters on the map and see if you can see any detail.
Set your Chart Detail to 'All', and your Spot Soundings to 'Visible'
on your unit so that you can see everything the map offers.
« Last Edit: August 16, 2012, 08:52:00 AM by ITGEEK »
Offline robbie48
  • Unit(s): 898c si
  • Software: ??
  • Accessories: gps
« Reply #2 on: August 16, 2012, 10:34:01 PM »
thanks for the reply.no,i was on smith mountain lake va.i have used the map card in my matrix 97 for several years works great in it.i have downloaded the manual and did everything it says to do.can't get a map of anykind to come up.but i'll try again tuesday.thanks again.ps.i have emailed hb help line and they said to download latest update but i read so much bad things about the update i hate to try it yet.
Offline Roddy
  • Scan,scan and rescan
« Reply #3 on: August 18, 2012, 01:47:39 PM »
robbie48, Check to see if the card is compatible with your unit.
Roddy
Scan,Scan and Rescan Roddy
Offline robbie48
  • Unit(s): 898c si
  • Software: ??
  • Accessories: gps
« Reply #4 on: August 18, 2012, 07:01:23 PM »
thanks.so,i guess some cards won't work?
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
« Reply #5 on: August 19, 2012, 11:54:50 AM »
try zooming out so you can see all of north america and reloading the card.... I had the same problem and that cured it right up....
Offline robbie48
  • Unit(s): 898c si
  • Software: ??
  • Accessories: gps
« Reply #6 on: August 19, 2012, 01:47:37 PM »
thanks all of you guys,but i can't get a map of anykind to come up.i know i'm very new to this 898 but i've used the matrix97 with map card since it came out.i'm probably just not doing something right.
« Reply #7 on: August 21, 2012, 01:16:50 PM »
If the map card worked in your Matrix 97 unit, than it should also work in your 898 unit – even if your 898 has older software in it.
Basically it is just plug and play here as long as you are trying to view an area that is covered by the mapping card.
Try testing your mapping card in someone else’s Humminbird unit to see if they can view any of the map detail.  The map card may have just went bad or the card readers in the 898 may have failed.  Confirm which it is by using a different unit.
Offline Beallright
  • Unit(s): 798 ci SI, 898c SI
  • Accessories: Interlink
« Reply #8 on: August 24, 2012, 07:59:03 AM »
I am having a similar issue with my 898, Mine will load and then drop the data. Was wondering if when you go to the GPS diag screen does the card show up in the card slot block? Can you download your data from your unit to another card with out issue? My Nav chip has a micro card inserted into a SD normal card. Does yours? I find that occassionaly my micro card becomes dismounted from the Regular card. Or the lock button becomes unlocked.
Offline robbie48
  • Unit(s): 898c si
  • Software: ??
  • Accessories: gps
« Reply #9 on: August 24, 2012, 05:52:38 PM »
i really just bought my unit not very long ago and haven't fooled with it much.i fished the fishers of men trail this summer and we fished out of my friends boat so i haven't had time until now to play with it.i just put in the map card and can't get it to work.boat stayes at smith mountain lake va. so i just get to try it out when we go down.wish i could give better info but can't.going to get my friend to try it in his unit.will check back later with results.
Offline flerias
  • Unit(s): humminbird 898
  • Accessories: 898
« Reply #10 on: November 19, 2012, 12:03:59 PM »
hello i need a portoguese cartography for my 898 .. exist freshwater?
Offline Rüdiger
« Reply #11 on: November 20, 2012, 04:09:27 AM »
Hi Flerias :)
Cards for inland waters and lakes you can make yourself with DrDepth.
mvh
Rüdiger
Finding is better than losing
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #12 on: November 23, 2012, 07:43:54 PM »
Maybe your map card isn't making a good connection inside the slot. Cut a small piece off a business card and wedge it  on the opposite side of the card that has the pins
« Reply #13 on: November 23, 2012, 09:48:38 PM »
If the above doesn't work, I would  first try the map card in both slots.
If that doesn't work, then remove the map card.
Then, reset your unit to default settings, then
set your Chart Detail to 'All', and your Spot Soundings to 'Visible'.
Then re-insert the card.
You know, it may also take some time for the maps to load into your unit.
It's not instantaneous.
Wait a minute or so for the 'Loading' message to go away.
If none of the above works, I'd go ahead and apply the newest
update and try again.
Good Luck.
« Last Edit: November 23, 2012, 09:49:58 PM by ITGEEK »
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
« Reply #14 on: January 05, 2013, 11:16:21 PM »
have you updated the card yet?  try updating and see if that helps.
Last post May 30, 2014, 08:32:26 AM
by jbrady2852
Last post February 28, 2011, 09:35:15 AM
by Kees Michielsen
Last post June 11, 2011, 07:11:32 PM
by stillbear
Last post May 23, 2010, 10:41:47 PM
Last post July 02, 2012, 09:40:28 PM
by HenryNguyen
Last post May 06, 2012, 11:47:03 AM
by wolfs4evr
Last post May 20, 2014, 01:20:00 PM
by CamoHunter
Last post August 18, 2020, 02:23:53 PM
