Author Topic: SD-Card for 898c SI  (Read 5844 times)
Offline Rüdiger
SD-Card for 898c SI
« on: February 07, 2011, 10:03:52 AM »
Hi :D
Which type and quantity of SD-Card kann the 898vc SI read ( SDHC....) ?
Mvh  Rüdiger
Finding is better than losing
Offline chet
  • Unit(s): 898c si
  • Software: latest
  • Accessories: none
Re: SD-Card for 898c SI
« Reply #1 on: February 07, 2011, 01:06:28 PM »
Sandisk 4,8,16gb extreme III class 10 which is read and write at 30mbs. I just used my 4gb for 4 hrs  on the boat amd wasn't even close to being full of data.
Offline Kees Michielsen
  • Boston Whaler Montauk fanatic
  • Unit(s): Helix9 G4N / HB998cx Si
  • Accessories: Autochart pro
« Reply #2 on: February 28, 2011, 09:35:15 AM »
From the FAQ section on www.humminbird.com :
Are your units compatible with the newer SDHC cards?
The answer to this question does depend on the model number of your product and also the software version you have loaded on your unit.  They are compatable with all 700, 900 and 1100 series products with color displays with softare version 3.7x0 or higher, On monochrome 700 series you would need version 3.8x0 and higher.  The highest capacity we support is 32G.  Older versions of software or older products will not be compatable.
Last post April 17, 2010, 06:52:35 PM
by neilbober
Last post April 12, 2010, 06:30:09 PM
by tennwalkinghorse
Last post March 25, 2010, 01:02:35 AM
Last post March 31, 2010, 08:25:11 AM
Last post January 25, 2011, 10:39:26 AM
Last post January 30, 2011, 02:20:17 PM
by slabbandit
Last post January 05, 2013, 11:16:21 PM
by Patty
