Author Topic: New 898c SI 83KHz doesn`t seem to work  (Read 7892 times)
Offline Barrajack
  • Unit(s): 898c SI
  • Software: 5.7
« on: May 05, 2012, 10:16:04 PM »
  :) Just new to this site and am wondering if someone can HELP!. After having 3 Lowerance sounders crack up with the same problem I bought myself a HB.898C SI and after setting it up cannot get a reading on the 83KHz screen. ( Even in simulation mode) Any help would be appreciated. By the way this is an excellent site, and am looking forward to being a regular visitor.
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: New 898c SI 83KHz doesn`t seem to work
« Reply #1 on: May 05, 2012, 10:32:28 PM »
I would call Humminbird Cust. Service.  Then maybe try your dealer.  Check owners manuel also.
Offline xSilmarilSx
  • Software: 6.250 - 5.320
« Reply #2 on: May 06, 2012, 12:04:52 AM »
The 83 kHz signal data is not present in the simulator files...
So it's normal that is blank in the simulator.
Offline wolfs4evr
« Reply #3 on: May 06, 2012, 11:47:03 AM »
Dito, nothing in simulator mode as far as 83khz (Blank screen).  You need to be out on the water.
Last post May 22, 2012, 03:52:12 PM
Last post June 11, 2011, 07:11:32 PM
by stillbear
Last post July 02, 2012, 09:40:28 PM
by HenryNguyen
Last post January 05, 2013, 11:16:21 PM
by Patty
Last post July 09, 2013, 02:20:58 PM
Last post June 02, 2014, 10:35:52 AM
Last post May 03, 2016, 11:42:30 PM
by fishreed
Last post April 28, 2020, 03:54:03 PM
