Author Topic: Adding Personalized text to your Start-up Screen using HummPC 4.3.3  (Read 17307 times)
I added a file to the Downloads section of the web site that has step-by-step directions on how to add personalized text to the start-up screen of your Humminbird unit using a memory card and the 4.3.3 version of HumminbirdPC.
http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=157
Offline Rough House
    • Rough House Charters
  • Unit(s): 1198c si / Helix 10
  • Software: latest
Re: Adding Personalized text to your Start-up Screen using HummPC 4.3.3
« Reply #1 on: August 01, 2012, 09:48:34 PM »
After you do all the steps, when you load the card into the unit does it save in the units memory or do you have to keep the card in all the time for the unit to display this?
Thanks. RH
Lake Erie Fishing out of Erie, Pa
« Reply #2 on: August 02, 2012, 07:44:05 AM »
It saves it..
Offline Kenai
    • Confidence
  • Unit(s): 598, Helix MSI+ 9 G4N, Helix 7 CHIRP G3N
  • Software: v7.300, v2.930
« Reply #3 on: June 21, 2024, 10:17:14 AM »
Hi, does this still work on new helix units?
If so, I have two SD slots and two cards in it. Both have PROFILE.TXT on them. If I change PROFILE.TXT files through Humminbird PC on firs one, will be the second one changed by unit? Just don't want to experiment on my unit, I have bad experience with 598 which developed strange fault. It refuses to save settings and also custom text is somehow set to version 10 years back with no chance to change it. This fault appears just after I add custom text. I'm thinking if this is coincidence, or I screw something on 598, and now it can't rewrite its memory. Even resetting to default does not help. It loads default, but after reboot, I'm back in my settings from 10 years ago. The same is true for custom text.
« Reply #4 on: June 21, 2024, 07:51:01 PM »
My first questions would be …
What unit do you have and what 2 cards do you have in the unit (2 map cards, 2 SD Cards, 1 map card and 1 SD Card)  ... ??
Offline Kenai
    • Confidence
« Reply #5 on: June 26, 2024, 02:12:26 PM »
Oh sorry, I don't mention it exactly.
Helix 9" MSI+ G4N international.
Slot1 32GB media card just for recording and waypoints tracks….
Slot2 Zerolines EU
Last post February 10, 2010, 10:46:03 PM
Last post November 02, 2011, 10:12:45 PM
by radeleur
Last post November 12, 2014, 09:10:58 PM
Last post May 15, 2012, 03:58:50 PM
Last post August 05, 2012, 09:55:22 PM
by lango73
Last post November 13, 2014, 06:39:03 PM
Last post April 15, 2015, 09:04:36 AM
by joemx1825
Last post July 14, 2018, 08:10:26 AM
by Togue Troller
