Author Topic: Unable to load custom boot text?  (Read 29243 times)
Offline joemx1825
  • Unit(s): 999ci HDSI
  • Software: 7.41
« on: March 19, 2015, 01:11:50 PM »
Does anybody have an image of the 9 series boot logo with added 4 lines of custom text?  I don't have access yet to my boat to test, but I heard the new Humminbird logo gets in the way of the 4 lines of custom added boot text you can add via Humminbird PC?
« Last Edit: April 14, 2015, 09:50:16 AM by joemx1825 »
2013 Skeeter MX1825
"My Hotfoot pedal goes to 11"
Offline joemx1825
  • Software: 7.41
Re: 9 series boot logo getting in the way of custom boot text?
« Reply #1 on: March 20, 2015, 11:08:13 AM »
I got an answer, no the new boot logo does not get in the way of the text, the old logo did...
2013 Skeeter MX1825
« Reply #2 on: March 20, 2015, 12:28:30 PM »
Really?  The old logo did not get in the way of the text on my 998c Si unit, but maybe I didn't have enough in each line.
Offline joemx1825
  • Software: 7.41
« Reply #3 on: March 20, 2015, 02:29:09 PM »
Thanks to "SFW1960" for the screenshot, the boot screen logo from version 7.020 got in the way of the text
2013 Skeeter MX1825
« Reply #4 on: March 23, 2015, 10:08:13 AM »
That would be the current 800 series unit and the new logo...
Offline joemx1825
  • Software: 7.41
« Reply #5 on: March 23, 2015, 04:46:41 PM »
so is the 999ci HD SI boot screen different?
2013 Skeeter MX1825
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #6 on: March 23, 2015, 05:40:33 PM »
ALL,
With the release of the latest v7.460 software  the boot logo changed to this:
From what was shown with v7.020 on my  899ci HDSI, I have heard the 999 logo also changed, though I do not own one. The 998c HDSI remains unchanged with v 7.510.
« Last Edit: March 23, 2015, 05:43:57 PM by sfw1960 »
Offline joemx1825
  • Software: 7.41
« Reply #7 on: April 14, 2015, 09:49:48 AM »
I can't get my custom text to load on my 999, I have the text added to the sd card via Humminbird PC, I powerup the 999 with the SD card in the slot and let it fully boot up,  I then power it down and back up but no custom boot text is visible..
2013 Skeeter MX1825
Re: Unable to load custom boot text?
« Reply #8 on: April 14, 2015, 11:33:15 AM »
Can you make and view a Screen Snapshot on that same memory card joemx1825?
Try powering the unit on first and then install the memory card.
Offline joemx1825
  • Software: 7.41
« Reply #9 on: April 14, 2015, 12:09:46 PM »
i'll test it tonight - Can I just leave the SD card in the unit once the boot text is loaded?  This will be my snapshot card too...
« Last Edit: April 14, 2015, 12:11:55 PM by joemx1825 »
2013 Skeeter MX1825
« Reply #10 on: April 14, 2015, 12:57:24 PM »
Yes you can.
What you will find is that if you put a blank SD card in there that the unit will load the same data to the memory card whenever you save a Screen Snapshot or export your waypoints, so either way the personalized text info ends up on the SD card.
Offline joemx1825
  • Software: 7.41
« Reply #11 on: April 15, 2015, 09:04:36 AM »
I finally got the boot text to load, but only after I went into my SD card and edited the profile.txt file manually.  If I tried to load the boot text via Humminbird PC it wouldn't work...just a heads up, editing the profile.txt is a heck of a lot easier!
2013 Skeeter MX1825
Last post July 02, 2011, 01:04:07 PM
Last post May 15, 2012, 03:58:50 PM
Last post July 23, 2012, 01:30:07 PM
Last post April 02, 2013, 07:01:32 AM
by wrktoomuch
Last post April 13, 2013, 04:29:22 PM
by wrktoomuch
Last post November 13, 2014, 06:39:03 PM
Last post March 27, 2020, 08:45:51 AM
by Jens
Last post May 27, 2020, 04:41:34 PM
by kevlar119
