Author Topic: Customise Start up Screen  (Read 16364 times)
Offline lango73
  • Unit(s): 788
« on: July 29, 2012, 11:05:22 PM »
I cannot seem to find the info previously posted here on how to add a message or your name etc to the start up screen by using the SD card in your pc to modify the start up screen message
Can anyone help?
Offline choc_e
  • Unit(s): 997si
Re: Customise Start up Screen
« Reply #1 on: July 30, 2012, 01:01:08 AM »
Offline lango73
  • Unit(s): 788
« Reply #2 on: July 30, 2012, 01:20:43 AM »
Perfect, thank you !!!!!!!!!!!!!!!!!
« Reply #3 on: July 30, 2012, 02:39:33 PM »
I would not suggest doing it that way.  I was warned by one of the Software Engineers against doing this (but have not heard of anyone having problems yet).  I recommend doing it the way it was meant to be done - by using HumminbirdPC:
http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=157
« Reply #4 on: July 30, 2012, 03:33:02 PM »
Profile is a .TXT file and can be edited by several programs.
This is also in the articles and tutorials by Jolly Rogers..
Does HBPC do something different than others?
Other than providing a screen with the 4 lines for update.
Possibly this could be a protection against writing on another line..which could then screw up the unit..
We all have to start thinking of these fishfinders as computers.
Which is why we are having problems with waypoints and trying to modify or import without the knowledge of what we are doing..or what the computer does..
chuck
« Last Edit: July 30, 2012, 03:44:38 PM by sonar2000 »
Offline George
  • Software: Always up todate
« Reply #5 on: July 31, 2012, 08:58:19 AM »
lango73
As Chuck states the Profile.txt is the file you want, you can find it on your SD card used for making recordings.  I keep a copy of the original file in case I  run into issues, but if something goes wrong I believe if you erase the file from the card and the unit will generate a new file.
Below is a copy of my Profile text file for my 1198:  You will see that changes can be made to P1 thru P4, not sure if you can add any more then P4.
Profile:Ver.1.000
Ver.6.310;Dat.Apr 16 2012;Rev.0;Spd.534Mhz
SEDB;0x00000002
SEDU;0x00016061
SEIB;0x00016061
SEIU;0x00000002
SENB;0xffffffff
SENU;0x00000140
SETB;0x00000140
SMDL;0x000000e6
SIMT;0xffffffff
WVER;0x00000002
RVER;0x00000003
TVER;0x00000003
P1;George Guise
P2;Lake Eufuala
P3;Feeding Falling Bar
P4;Dormant Rising Bar
George
« Reply #6 on: July 31, 2012, 07:10:27 PM »
I have found out the hard way when editing computer programs with a text editor offline and then importing it into another application that all text editors are not equal.  Some text editors .... even though you save the file as a .txt file will have special characters imbedded in the file that are not visible.  They are control characters that control spacing, paragraphs, end of line, etc, etc.
Until I learned this, I had wasted time editing a program offline and then importing it into the standard programming software only to have all kinds of problems that are caused by the invisible special characters.
I would go with Gregs suggestion and used the recommended editing method....just another thing that may prevent corrupt data in your unit.
« Reply #7 on: August 02, 2012, 07:35:27 AM »
You are on track Bob.
these are now computers and we have to learn to be smarter when making changes.
If you are not a computer person then use thew factory tools.
If you understand computers you can side step.
The next thing is see is social media sonar.. ;D
« Last Edit: August 06, 2012, 05:08:52 PM by sonar2000 »
Offline gramps50
  • Unit(s): 597ci HD DI
  • Software: 6.09
« Reply #8 on: August 02, 2012, 04:16:06 PM »
Unless things have changed you do NOT want to use Notepad in Windows as it is not a true text editor. Back in my Windows days I used NoteTab as my text editor.  There are a few other pure text editors for Windows too.
Notepad will put extra characters in the file.
I used gedit in Linux to edit my file and did not have any issues.
Offline lango73
  • Unit(s): 788
« Reply #9 on: August 05, 2012, 09:55:22 PM »
Thanks all for your replies, info has been very helpfull.
Last post February 10, 2010, 10:46:03 PM
Last post March 23, 2010, 09:10:49 AM
Last post April 01, 2010, 03:13:37 PM
by kerv
Last post June 28, 2012, 07:32:08 PM
Last post June 26, 2024, 02:12:26 PM
by Kenai
Last post January 23, 2015, 02:01:29 PM
Last post May 19, 2015, 03:20:37 PM
by Jimmy B
Last post September 18, 2015, 08:18:05 AM
by nicknight
