Author Topic: son2xtf.exe?  (Read 15103 times)
Offline equinox
  • Unit(s): 997 C
son2xtf.exe?
« on: July 29, 2010, 02:53:58 PM »
According to the maker of Drdepth there should be a "son2xtf.exe" that converts the information according to "Humminbird sonar log files (.dat)', you must first place a copy of Humminbird's data converter utility 'son2xtf.exe' in the install directory of DrDepth. You can get this utility program from Humminbird (due to licensing this program can not be included in the DrDepth installer). With 'son2xtf.exe' in place, select your .dat file(s) to be imported (in this case R00005.DAT)." how do I find this  son2xtf.exe?
Re: son2xtf.exe?
« Reply #1 on: July 29, 2010, 03:34:51 PM »
One of two ways.  Go to Humminbird.com and register your unit.  Then login to your account and it will be listed in the downloads next to your unit.
Or you can find it here on the forum in the Donwloads section.
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=13
Good Luck,
Offline equinox
  • Unit(s): 997 C
Re: son2xtf.exe?
« Reply #2 on: August 01, 2010, 04:05:58 AM »
I already had it on the computer....
How do I record or save the .son and .dat files?
I have the computer with the Dr.depth program connected and it records, calculates and produce the normal depth maps.
But for the bottomhardess maps and the SI projection it needs the .son and .dat files.
I have been informed that there should be a register named R0000x where do I find that one?
My 200 Hz is running all the time.
Re: son2xtf.exe?
« Reply #3 on: August 01, 2010, 12:16:51 PM »
When you record a scan the HB places a file on the sd card called RECORD. That file contains a R000XXX.dat file and an associated R000XXX file.  In the R000XXX file are the three recordings .IDX and associated .SON files. B001 thru B003.
You copy these to where ever your viewing program is.
Offline equinox
  • Unit(s): 997 C
Re: son2xtf.exe?
« Reply #4 on: August 01, 2010, 01:13:34 PM »
Thanks again, I´ll try that.
Offline equinox
  • Unit(s): 997 C
Re: son2xtf.exe?
« Reply #5 on: August 01, 2010, 06:29:24 PM »
Now everything works, thanks alot once again.
Last post May 17, 2010, 03:24:37 AM
by ruiner
Last post January 10, 2012, 12:56:26 AM
by T.G
Last post July 02, 2012, 10:12:32 AM
by Roddy
Last post March 22, 2013, 09:04:51 PM
by wickgofish
Last post November 12, 2018, 02:29:38 PM
by wami
Last post May 27, 2019, 12:17:11 PM
by LHayden
Last post April 29, 2021, 08:40:08 AM
by BobRisner
Last post November 21, 2021, 10:40:49 AM
by abraquelebout
