Author Topic: Helix to Son2xtf to DeepView FV - Video  (Read 13162 times)
Offline BobRisner
  • Unit(s): Onix, Helix 10 and Helix 12
  • Accessories: 5 Port Hub, Mega 360, Heading Pucks
« on: April 29, 2021, 08:44:06 AM »
Here is a short video I did on how to get more out of your Helix units.
Hope it helps,
Bob....
Offline Kees Michielsen
  • Boston Whaler Montauk fanatic
  • Unit(s): Helix9 G4N / HB998cx Si
  • Accessories: Autochart pro
Re: Helix to Son2xtf to DeepView FV - Video
« Reply #1 on: May 22, 2021, 09:34:37 AM »
Thanks Bob,
I received the program son2xtf and it works :-)
Greetings from Holland !
Offline Rüdiger
« Reply #2 on: May 23, 2021, 04:30:30 AM »
Hi bob
Thanks for the really good video, great job.
The Son2xtf Converter can be downloaded here in the forum:
http://forums.sideimagingsoft.com/index....sa=view;down=26
mvh
Rudiger
Finding is better than losing
Offline Rüdiger
« Reply #3 on: May 24, 2021, 08:01:55 AM »
That was the wrong link :o, here is the right one:
http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=26
mvh
Rudiger
Offline tournevase
  • ARCHAEOLOGICAL SURVEY
    • GRAS
  • Unit(s): HELIX 10 G4N CHIRP MEGA SI +
  • Software: AUTOCHART PRO
« Reply #4 on: November 09, 2021, 06:41:57 AM »
Hello
i try to convert .dat data to .xtf     i know that Son2xtf can be used
i download Son2xtf in .msi and converted it to .exe but it needs  adding .net or others things ..... my head is exploding !
has somebody an .exe issue easy to install on windows 10 ?
or are there viewers able to eat .dat files
Tournevase
Offline BobRisner
« Reply #5 on: November 09, 2021, 07:02:28 AM »
I'm running Son3xftf on two different computers with Window 10 with no issues. I did not convert anything I just ran the installer and used the program. I'd uninstall it and then reinstall it once again.
Bob...
Offline tournevase
    • GRAS
« Reply #6 on: November 09, 2021, 07:14:50 AM »
thank you bob
i looked for Son3xftf on the web but no results
where can it be downloaded please ?
Tournevase
Offline BobRisner
« Reply #7 on: November 09, 2021, 08:45:01 AM »
Send me your email and I'll send you a link.
Offline tournevase
    • GRAS
« Reply #8 on: November 09, 2021, 09:48:22 AM »
problem solved
i installed with success in XP then copied the files on w10
then i installed deep vision software and it works perfectly
i can now see the remains of hydraulics installation built by king Louis XIV to provide water for the chateau de versailles gardens
thank you for your help
Tournevase
Offline Rüdiger
« Reply #9 on: November 10, 2021, 03:11:37 AM »
Hi tournevase
You should post pictures of it .
mvh
Rüdiger
Offline abraquelebout
« Reply #10 on: November 21, 2021, 10:40:49 AM »
hi all
It's cool video, but one thing is forget...Deepview3 make georef report in  the total pics and don't corect the depth...if you want the exact gps point you must deplace cursor in right or left to value of depht, it work with distance of towfish too. You take the mesure tool, mesure depht and report the value in midle of pics direction...put the cursor and read the rigt position...it work well ;)
the value corrected is not important if there's no more depht but after 7 meter it's important, imagine if there's 30 or 50 m...whe can also correct towfish deport...
Last post May 17, 2010, 03:24:37 AM
by ruiner
Last post August 01, 2010, 06:29:24 PM
by equinox
Last post January 10, 2012, 12:56:26 AM
by T.G
Last post July 02, 2012, 10:12:32 AM
by Roddy
Last post January 31, 2018, 09:21:53 PM
Last post February 06, 2019, 09:58:37 AM
by Colorado #5
Last post May 27, 2019, 12:17:11 PM
by LHayden
Last post April 29, 2021, 08:40:08 AM
by BobRisner
