Author Topic: gr16/4 gps on 597c  (Read 11949 times)
Offline mcbillw@gmail.com
  • Unit(s): 597c
  • Software: ?
  • Accessories: gps
gr16/4 gps on 597c
« on: February 07, 2012, 11:00:28 PM »
need info/schematic or pin out on the actual receiver where wires plug in, damaged mount and wire, and I have everything put together but there are two identical plugs with diff colors, need to know the left to right colors, or which plug goes left and right, black & red and white and green, what is order? any info appreciated, have looked every where in support & can't find that info...mcbillw
Re: gr16/4 gps on 597c
« Reply #1 on: February 08, 2012, 08:27:00 AM »
Here is the link to the receiver manual.  See if this helps..
Look at page 2, 3 and 4....
http://www.humminbird.com/PDF/AS_GR16.pdf
« Last Edit: February 08, 2012, 08:30:40 AM by sonar2000 »
« Reply #2 on: February 08, 2012, 11:43:36 AM »
mcbillw,
Are you talking about the plugs that are internal in the unit or the GPS Receiver’s connection plug?  Pictures used to be worth a thousand words before inflation but are still good at clarifying what you need to know.
« Reply #3 on: February 08, 2012, 12:42:14 PM »
A picture is still worth a thousand words. Inflation does not change the picture. the wires and cable are the same..
In a nutshell the GPS receiver has a wire that comes out of it and goes to a connector that connects to the unit.
The connector at the unit end of the cable has a pigtale cable to link another nema device sentence. The wires are common in the cable end that plugs into the unit.
Where exactly did you break the wire and did you break any connector??????
chuck
« Last Edit: February 08, 2012, 04:46:40 PM by sonar2000 »
« Reply #4 on: February 08, 2012, 04:43:56 PM »
The damage was to the GPS Receiver cable.
mcbillw was hoping to just reattach the cable to the PCB inside the GPS Receiver but the cables are epoxied in place so that they do not leak.  There are two sets of connectors inside and they are labeled and so he wanted to know the correct connection for these.
« Reply #5 on: February 08, 2012, 04:49:16 PM »
The link I posted should give him the right wire and color to solder in place..
I dont know if I would go inside of the receiver and make any connections.
As long as he did not break a connector he should be able to mend the wires...
« Last Edit: February 10, 2012, 08:20:25 AM by sonar2000 »
« Reply #6 on: February 10, 2012, 08:12:53 AM »
mcbillw,
Have you gotten your GR4/16 GPS Receiver back up and running yet?
Last post October 24, 2009, 09:43:22 PM
Last post May 27, 2010, 09:30:57 PM
Last post February 27, 2012, 07:38:04 PM
by rdstair
Last post July 11, 2012, 12:56:40 PM
Last post February 04, 2013, 11:15:31 PM
by johnca51
Last post August 29, 2014, 03:18:04 PM
by Tom Wolter
Last post July 05, 2015, 03:23:42 PM
by Monty
Last post March 29, 2017, 09:11:09 PM
