Author Topic: Screen Orientation  (Read 12176 times)
Offline gramps50
  • Unit(s): 597ci HD DI
  • Software: 6.09
Screen Orientation
« on: June 18, 2012, 12:11:04 AM »
This sonar stuff is all new to me, I just purchased a 597ci HD DI it's mounted on my trolling motor for used from the front of the boat as that is where i fish 90% of the time.
The screen scrolls from right to left, isn't what I'm seeing actually front to back? Or am I missing something here?
Re: Screen Orientation
« Reply #1 on: June 18, 2012, 07:34:41 AM »
I'm not sure I understand what you mean as to front to back.
What you are seeing is based on where your transducer is actually pointed down
into the water.  The deeper the water, the bigger the coverage cone gets.
Right to left is the standard way that 2-D sonar is displayed.
Think of what's on the furthest right side of the screen as new information, and
anything to the left of that as old information.
Offline gramps50
  • Software: 6.09
« Reply #2 on: June 18, 2012, 10:29:14 AM »
I understand the cone angle on the deeper the water the more of the bottom you can see.  Maybe I am  over thinking the whole thing.
What I was curious about was what I'm seeing scroll right to left on the screen is that scrolling right to left under the boat or front to back?
Maybe this will help if I saw a large school of fish go across the screen and I wanted to present some bait to that school chances are where would I want to cast my lure to the left side or the rear?
Hope I'm not confusing matters more....
« Reply #3 on: June 18, 2012, 11:35:08 AM »
This might help you to visualize how it works.
You have your transducer attached to your trolling motor on the front of the boat.
You lower a jig (on a line) to the bottom.
You raise it off the bottom.
On the right side of your screen, you can see the line and the jig.
The screen information you just saw keeps moving to the left.
It is now old.
You lower and raise your jig again.  You can see this information on the far right of the
screen again.
If you use the RTS(real time sonar) with your 2-d view, you can see what is happening
in real time.  Every time you move that jig, you will immediately see the movement on the RTS section of the screen (very far right).
It will only show fish that pass through the sonar cone.
This will probably include fish towards the back of your boat only if you are in very deep water.
Also, if you 50mhz, it will show a bigger cone.
I think if you use the DI, then you will see a real-time picture view.
It doesn't scroll.
If you see fish on your 2-d sonar, I would lower the bait/lure right below the transducer.
« Last Edit: June 18, 2012, 11:37:01 AM by ITGEEK »
Offline gramps50
  • Software: 6.09
« Reply #4 on: June 18, 2012, 12:33:42 PM »
Duh!  Why didn't I think of doing that? I will give that a try next time I am out.  Thanks ITGEEK
Why do I have to type verification letters each time I post?
« Reply #5 on: June 18, 2012, 12:51:37 PM »
If you joined the forum, I don't know why you would have to verify each post.
Maybe Chuck can shed some light on it.
Good luck on the water.
Offline gramps50
  • Software: 6.09
« Reply #6 on: June 18, 2012, 12:57:53 PM »
Yes I had joined before I posted. Just posted on another tread and it didn't ask.   ::)
« Reply #7 on: June 18, 2012, 02:19:24 PM »
On the Split Screen Sonar View the frequency on the left is the 83kHz.  The lower frequencies are more likely to show surface clutter and zooplankton stronger than the higher 200kHz frequency will.  I would not move the transducer for this.
The DI sonar displays the same as 2D sonar does: newer information on the for right side with older historical data scrolling to the left side.  If you are heading straight forwards with your trolling motor pointed straight forwards; than the fish you see on the display could be well behind the boat.  To see how far away they are just use the cursor and move it over them and the unit will tell you how far away they are.
« Reply #8 on: June 18, 2012, 02:21:04 PM »
Dont know why you would have to type verification information.  Let me know in a pm if you have this problem again.
Offline W9GFO
  • Unit(s): 798ci HD SI
« Reply #9 on: June 18, 2012, 02:27:39 PM »
I had to type the verification numbers for the first few posts, then it went away.
« Reply #10 on: June 18, 2012, 02:32:03 PM »
ok......let me know if it happens again....chuck
Offline gramps50
  • Software: 6.09
« Reply #11 on: June 18, 2012, 02:35:39 PM »
Only happened for the first several post then it didn't ask any more. I will PM you if it happens again, Thanks
Allen
Offline gramps50
  • Software: 6.09
« Reply #12 on: June 18, 2012, 02:38:38 PM »
Thanks Greg that answers my question
Last post January 22, 2012, 08:28:45 PM
Last post March 25, 2011, 03:30:51 PM
Last post April 08, 2011, 01:11:40 AM
by stillbear
Last post May 26, 2011, 11:54:44 AM
by jazzybean
Last post June 16, 2011, 01:47:15 PM
Last post October 17, 2011, 04:15:35 PM
Last post February 20, 2014, 09:56:43 PM
