Author Topic: di screen black  (Read 17448 times)
Offline jazzybean
  • Unit(s): 597ci hd di
  • Software: 5.470
di screen black
« on: May 19, 2011, 04:04:17 PM »
Help needed please,  i have a 597ci hd di unit which i used for the first time on sunday. The gps and normal sonar worked fine but what ever i tryed the 3d imaging just showed up as a blank black screen. Maybe im missing some thing, so any help would be good. Thanks Darren uk.
Re: di screen black
« Reply #1 on: May 19, 2011, 05:22:20 PM »
Darren, which sonar transducer did you receive with your unit?
Offline jazzybean
  • Software: 5.470
Re: di screen black
« Reply #2 on: May 19, 2011, 05:47:38 PM »
Hi chuck,  XNT 9 DI T.
Re: di screen black
« Reply #3 on: May 19, 2011, 07:22:47 PM »
Sounds like you have the right transducer.  Just wanted to make sure you were shipped the right one.
So you are saying the 2D regular sonar is fine  and that when switching to DI it goes black..
Offline jazzybean
  • Software: 5.470
Re: di screen black
« Reply #4 on: May 20, 2011, 03:45:24 AM »
Yes the 2d seemed to work mostly fine, maybe a little glitchy. Then when i switch to the 3d screen the depth lines show up fine just now blue images , it just stays black...  Im not sure if the way ive mounted the tranducer may be the problem, as ive mounted it in the hull off my fiber glass boat using resin as instructed.
Offline robman
Re: di screen black
« Reply #5 on: May 22, 2011, 05:14:17 AM »
There maybe your problem, I know the side image transducer will not work through the hull so I am guessing the down image transducer part of your transducer will not work through the hull but the 83 and 200 Hz will.
Rob
Offline jazzybean
  • Software: 5.470
Re: di screen black
« Reply #6 on: May 24, 2011, 05:31:23 AM »
Thanks rob, it looks like you are right. I removed the tranducer from the hull and put it in a water butt , i then got good readings on both 2d and 3d. so will will have to go for a transome install.
Thanks alot Darren.
Re: di screen black
« Reply #7 on: May 24, 2011, 02:30:35 PM »
Darren,
If the unit is now showing DI sonar with the transducer in the water but not in the hull than the problem was the installation of the DI transducer.  May have been an air bubble or something under that portion of the transducer (the element for the 2D sonar is on the fatter rounder end of the transducer while the DI sonar comes from the more narrow pointed end).  When you tested the transducer inside-the-hull before epoxying it in place, did the Di sonar work well than?
Offline jazzybean
  • Software: 5.470
Re: di screen black
« Reply #8 on: May 26, 2011, 11:54:44 AM »
ive fitted the tranducer to the transome with good results. so thanks for all the help, darren.
Last post June 23, 2010, 04:55:41 PM
Last post September 10, 2011, 04:15:11 PM
by JiminFL
Last post April 13, 2012, 09:43:46 AM
Last post May 10, 2012, 08:59:30 AM
Last post August 25, 2014, 02:48:54 PM
by ScottSp
Last post June 10, 2015, 04:27:29 AM
by navionic
Last post September 23, 2016, 07:07:39 PM
by etmci
Last post June 08, 2020, 11:06:04 PM
