Author Topic: 798 gps questions/problems?  (Read 5228 times)
Offline wishn i was fishn
  • Unit(s): 798
« on: May 12, 2012, 08:06:04 AM »
I have had my 798 for about a year and a half now.  I recently have come across some gps coordinates that I wanted to manually enter.  After entering about 25 waypoints and reviewing them, I realized that the actual location was way off of the desired location, as I have an aerial photo to refenece.  I also entered them into a handheld and those waypoints are correct.
It seems that the newly created waypoints are nearly 1/4 off.  How do I correct this?
If I cursor approximately over the desired location the coords are way off, to the actual coords.
Also when entering waypoints my 798 will  only allow me to enter 7 digits instead of 8 like many others.  Why is that?
example  humminbird       39  06  49.0
others                              39  06  49.00
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: 798 gps questions/problems?
« Reply #1 on: May 12, 2012, 10:37:11 AM »
Just make sure that you are using the same Datum (WGS84 or others) that match the paper map or aerial photo with what the unit is setuped for.
« Reply #2 on: May 12, 2012, 04:01:48 PM »
There should be an option under your Waypoint menu for
the format type of the coordinates.
There are 4 or 5 different types, so you may
not be keying them in correctly.
??.????? degrees is the most accurate format.
« Reply #3 on: May 14, 2012, 10:49:29 AM »
The Position Format menu is under the Setup menu tab.
You are correct in that the dd.ddddd menu setting is the most accurate.
The waypoint example you posted wishn looks to be in the Degrees Minutes Seconds format.  Some allow the addition of decimal seconds but so far Humminbird has not.  This has been asked for but has not been changed.
As for the waypoints being off: are they off according to the map that is being displayed on the unit or are they off because you have actually traveled to these places?  I ask because the map may be off for the lake that you are looking at – which is a separate thing than the actual waypoint being off.  You do need to make sure that you are using the same Map Datum and coordinate format but this is another reason why the waypoints could look off but be accurate.
Last post April 08, 2010, 02:51:31 PM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post November 08, 2011, 12:56:58 PM
Last post April 12, 2012, 05:56:34 PM
by Emma Clarke
Last post April 18, 2012, 10:39:32 PM
Last post September 26, 2012, 02:14:16 PM
Last post August 10, 2014, 11:08:10 PM
