Author Topic: 899 ci hd si questions  (Read 8020 times)
Offline cary
  • Unit(s): 798 ci hdsi
« on: August 10, 2014, 08:55:30 PM »
I am about to order a 899 unit.  Of all I have read, exchange the transducer for the HD model.  May have problems with the 800 Hz until Hummingbird gets it fixed or have they done that yet.   I have a Ranger 185vs, on all the new big rangers they have the transducer thru hull. Is that something that I should consider or just mount to transom. If anyone has pics of mounting transducer on a ranger please send.   The boat has an indash garmin (junk but reads depth and its a shoot thru hull)  will it interfere with the 899 unit.  The Ethernet hookup is it simple or do you have to have other parts to make it work (probably gonna get another next year).  Will the transducer for the 899 interchange for the 999 unit if decide to go bigger.
Re: 899 ci hd si questions
« Reply #1 on: August 10, 2014, 11:08:10 PM »
HB has been able to offer the fix for the 800kHz washout in the xx9 series units...(your future unit may already be fixed before you even get it)...
http://www.bbcboards.net/humminbird-sonar-gps/513899-update-software-fix-800khz-si-di-issues-899-etc.html
_________________
Ranger installation pix here...
http://www.bbcboards.net/humminbird-sonar-gps/172972-installation-networking-information-resource.html
_________________
If the Garmin transmits at 200kHz ... There can be interference issues because the HB cannot shut off the 200kHz frequency except by turnin off the entire sonar sounder and leaving only the GPS operational ...
__________________
Ethernet is simply a cable long enough to reach between the devices...
http://www.humminbird.com/Freshwater/Product-Category/Accessories/Cables/?facets=7319,
*xx9 series units also need the AS EC QDE adapter cable ...
http://www.humminbird.com/Products/AS-EC-QDE/
*Ethernet connecting more than 2 devices (head units and/or Ethernet accessory devices) ...also need the Ethernet switch ...
http://www.humminbird.com/Products/AS-ETH-5PXG/
______________
The XNT 9 SI 180 T comes stock with the 899 ...
The XHS 9 HDSI 180 T comes stock with the 999/1199 ...
The XNT 9 SI 180 T (Compact SI xducer) can be used on the 999 but there will be no correct 800kHz frequency images from this xducer as the Compact SI xducer is 83kHz/200kHz (2d) and 455kHz (SI) only...
« Last Edit: August 10, 2014, 11:14:27 PM by rnvinc »
Last post April 08, 2010, 02:51:31 PM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post November 08, 2011, 12:56:58 PM
Last post May 14, 2012, 10:49:29 AM
Last post January 22, 2013, 04:16:17 AM
by Rüdiger
Last post January 22, 2015, 08:43:19 AM
Last post October 25, 2015, 09:11:53 PM
