Author Topic: recording questions  (Read 7907 times)
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
recording questions
« on: April 16, 2012, 08:04:57 PM »
 How do I view my recording on my pc?
Re: recording questions
« Reply #1 on: April 16, 2012, 08:46:50 PM »
One common used viewer is humviewer. there are several others but lets start with humview. It does not take any conversion programs..
You install on your computer and then put your recording (sd card) in your reader. It goes better if you copy the recording to a file on your computer...
I will be  right back with a couple of other hints..
OK. you can go here to get humviewer.  the latest is 67 I think..
http://humviewer.cm-johansen.dk/
It is free.
Once you have it down loaded let us know and we can talk you thru the usage..It is real simple..
« Last Edit: April 16, 2012, 08:51:37 PM by sonar2000 »
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
« Reply #2 on: April 17, 2012, 08:25:53 PM »
 Chuck got it install and attempted to open files from card but said I need to install google earth
« Reply #3 on: April 18, 2012, 10:00:45 PM »
Humviewer as basic has nothing to do with google earth so not sure of the message. It runs on its own.
Refresh:
1) open humviewer
2) program loads and has screen without sonar data.
3) upper left top click on open file
4) select the sd card drive and open the file called record
5) select the r000xxx.dat file name.
What is happening different on yours.
« Last Edit: April 18, 2012, 10:37:31 PM by sonar2000 »
« Reply #4 on: April 18, 2012, 10:39:32 PM »
This will not make much difference, but for a faster load of the recorded data if you copy the sd card to a computer file it will load the data quicker.
If I confused you just say so and I will explain again..
Chucki
Last post April 08, 2010, 02:51:31 PM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post November 08, 2011, 12:56:58 PM
Last post July 10, 2013, 09:51:07 PM
Last post August 10, 2014, 11:08:10 PM
Last post January 22, 2015, 08:43:19 AM
Last post October 25, 2015, 09:11:53 PM
