Author Topic: dual transducers y cable problem  (Read 12142 times)
Offline goodwinexplorer
  • Software: 4.18
« on: April 22, 2012, 08:59:27 AM »
i am fitting 2 through hull transducers as i have a deep keel ,i have tested them with a as side y-splitter cable 720055-1 the cable is labeled side and dual beam and it only seems to work with the plug labled  side, plug in, is this the correct cable? or do i need to switch some thing on in the unit?
i notice the cable you mention is as-si-db-y cable.
Any help please
Re: dual transducers y cable problem
« Reply #1 on: April 23, 2012, 10:22:56 AM »
If you are connecting two Side Imaging transducers together you need the AS-Si-LR-Y cable (720056-1).
« Reply #2 on: April 23, 2012, 10:33:09 AM »
AS SILR Y
Transducers
720056-1
Side Imaging Splitter Cable
Y Cable - Separates Side Imaging into Left and Right Beams - for Side Imaging products only. Allows the use of two side imaging transducers with one unit without the need for a transducer switch. Used in applications where the a plastic thru the hull transducer is required on a boat with a deep V hull. Can also be used if the motor or other items on the exterior of the boat may block one side of the transducer and distort readings.
Check on line for pricing..
  • Software: 4.18
« Reply #3 on: April 23, 2012, 01:08:20 PM »
thanks, they sold me the wrong cable
« Reply #4 on: April 23, 2012, 01:11:57 PM »
"they" may not have understood the connection you wanted.  If new "they" should swap..
Last post March 16, 2010, 06:08:28 PM
Last post April 05, 2010, 11:00:29 PM
by blharr4400
Last post January 03, 2011, 01:12:25 PM
by keizerh
Last post January 24, 2011, 03:59:01 PM
by Kennyscott
Last post July 22, 2011, 11:21:09 PM
by stratofisher
Last post November 03, 2014, 09:41:00 PM
Last post September 15, 2014, 01:07:28 PM
Last post December 06, 2016, 09:17:49 AM
by trogersIII
