Author Topic: Aluminum Jet Boat install- dual HDSI transducers + Alumaducer  (Read 12728 times)
Offline stratofisher
  • Unit(s): 1197C SI NVB
  • Software: 5.840
I am planning on installing my 1197 on the jetboat with dual SI transducers connected with the Y cable to give effective left and right.  I plan to run from the Y cable into a TS3 switch so that I can utilize my Alumaducer thru hull for high speed 2d.  I figured this way I could use the HB 2-d off the SI transducer at slow speed and switch to the Alumaducer through hull for high speed depth.  Was using the Alumaducer with my previous X-15 Lowrance and it worked well.  Have heard that it should work with the HB given that I have the proper adapater cable- which I do have now.   Any issues with this proposed setup.  Have read some previous posts on the hazards of switches.  Just want to make sure I have it all connected in a good configuration.
Re: Aluminum Jet Boat install- dual HDSI transducers + Alumaducer
« Reply #1 on: July 12, 2011, 11:59:59 AM »
I would make sure and change the Transducer Select menu setting before changing from the Si transducers to the AlumaDucer (and change it back after switching back to the Si transducers).
  • Software: 5.840
« Reply #2 on: July 22, 2011, 11:21:09 PM »
Finally got it all installed.  Works as advertised.  I love this new side scan sonar.  A bit of cash wrapped up with the switch and extra transducers, but wow is all I can say.  Feels like cheating fishing with this setup.  The dual setup works great.  Glad that I went that way.
Last post March 16, 2010, 06:08:28 PM
Last post April 05, 2010, 11:00:29 PM
by blharr4400
Last post January 03, 2011, 01:12:25 PM
by keizerh
Last post January 24, 2011, 03:59:01 PM
by Kennyscott
Last post March 11, 2011, 11:47:15 PM
by reddog
Last post August 04, 2011, 10:13:41 PM
by stratofisher
Last post September 03, 2014, 12:11:17 PM
by Free2Fish
