Author Topic: Can't select the transducer on the 788ci DI !  (Read 9493 times)
Offline laurin_ch
  • Unit(s): 1
  • Software: 6.?
  • Accessories: quadra beam
« on: April 06, 2012, 02:53:52 PM »
Hey guys
I recently purchased a QuadraBeam Transducer for my 788ci DI.  I tried everything to get to the "transducer select"-tab but I just can't find it.  Am I stupid? The system is on the newest software available.
Thanks for your help.
Laurin
Re: Can't select the transducer on the 788ci DI !
« Reply #1 on: April 06, 2012, 04:15:36 PM »
I think the latest release repositioned some of the places where things used to be.
Also look and see ifn youhave advanced mode set to advanced..
« Reply #2 on: April 06, 2012, 04:22:53 PM »
You can stop looking – and it isn’t a software mistake.
The DI units (788ci D among them) does not have this menu because there is only one transducer type that works with this transducer: the DI transducer (either the transom, inside-the-hull or trolling motor version).
The 788ci DI unit was never meant to work with the QuadraBeam transducer but the (non-DI) 788ci unit is and has that menu.
Offline jbrady2852
  • Unit(s): 999ci HDSI, 788ci DI
  • Software: 7.020
« Reply #3 on: April 09, 2012, 08:26:38 AM »
I am curious about this one because I am about to purchase it.  The HB website lists the 788ci HD as a suitable unit.  It is my understanding that you can't use the Y cable but have to use the TS3 switch to switch between them if you plan on still using the DI features.  If this is not the case please along the info.
« Reply #4 on: April 09, 2012, 10:52:28 AM »
I don’t have time to check the Humminbird web site right now jbrady2852 but was this under the listing for the QuadraBeam transducer?
Laurin got the QuadraBeam use information from the original version of the operations manual which was wrong.  It has since been corrected.
Offline jbrady2852
  • Software: 7.020
« Reply #5 on: April 09, 2012, 01:01:38 PM »
It is listed in the unit documentation and on the tranducer spec sheet.
« Last Edit: April 09, 2012, 01:04:27 PM by jbrady2852 »
« Reply #6 on: April 09, 2012, 01:38:03 PM »
Hate to be a pain about this but I looked for this in both the product pages as well as the different versions of the QuadraBeam transducer and I still cannot find it.  Could you post some links for me please?
Offline jbrady2852
  • Software: 7.020
« Reply #7 on: April 09, 2012, 01:42:12 PM »
Greg, you are 100% right.  I could have swore that the DI unit was listed on the transducer list.  So glad I saw this thread before I purchased the quadrabeam unit.
Last post August 24, 2010, 04:09:54 PM
Last post October 18, 2011, 02:38:56 PM
Last post April 09, 2012, 09:59:55 AM
Last post April 28, 2014, 08:54:37 AM
by rdico
Last post August 16, 2014, 08:58:34 AM
Last post October 16, 2014, 08:11:22 AM
by Fly 1
Last post June 18, 2015, 08:47:37 AM
Last post August 27, 2015, 07:15:29 PM
by burgersb
