Author Topic: Can't select the transducer on the 788ci DI !  (Read 7493 times)
Offline laurin_ch
  • Unit(s): 1
  • Software: 6.?
  • Accessories: quadra beam
« on: April 06, 2012, 02:45:19 PM »
Hey guys
I recently purchased a QuadraBeam Transducer for my 788ci DI.  I tried everything to get to the "transducer select"-tab but I just can't find it.  Am I stupid? The system is on the newest software available.
Thanks for your help.
Laurin
Re: Can't select the transducer on the 788ci DI !
« Reply #1 on: April 06, 2012, 04:14:13 PM »
I think this last release of code put some stuff in a different place. Will look around  for it.
Make sure you have advanced mode set to on.
chuck
« Reply #2 on: April 06, 2012, 04:22:47 PM »
You can stop looking – and it isn’t a software mistake.
The DI units (788ci D among them) does not have this menu because there is only one transducer type that works with this transducer: the DI transducer (either the transom, inside-the-hull or trolling motor version).
The 788ci DI unit was never meant to work with the QuadraBeam transducer but the (non-DI) 788ci unit is and has that menu.
« Reply #3 on: April 06, 2012, 04:35:56 PM »
Good point Greg.  See how easy it is to confuse similiar models..
Maybe the next generation will not have closely similiar names..
Remember the old days when you bought a ford, chevy or buick...Look at them today.. ;D :o
« Last Edit: April 06, 2012, 04:37:09 PM by sonar2000 »
« Reply #4 on: April 09, 2012, 09:59:55 AM »
Part of the confusion here was that there was a statement in the first version of the operations manual that said that the 788ci DI units had the QuadraBeam menu option.  The current version has been corrected.
There may not have nee the confusion if the model names were not so similar and the fact that they (all the 788 models) now use the same operations manual…
Last post August 24, 2010, 04:09:54 PM
Last post October 18, 2011, 02:38:56 PM
Last post April 09, 2012, 01:42:12 PM
by jbrady2852
Last post April 28, 2014, 08:54:37 AM
by rdico
Last post August 16, 2014, 08:58:34 AM
Last post October 16, 2014, 08:11:22 AM
by Fly 1
Last post June 18, 2015, 08:47:37 AM
Last post August 27, 2015, 07:15:29 PM
by burgersb
