Author Topic: transducer select  (Read 7053 times)
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
transducer select
« on: October 17, 2011, 04:44:30 AM »
Hi, i`m trying to find out some info on which setting i should put my transducer on,in the sonar set up menu there is the option "transducer select",there are 7 set up options;hi-def sidescan,compact sidescan,sidescan,quad beam,dual beam,dual 50/200,universal sonar.Can some one please either tell me where i can find some info on this or please explain which one i should be using, am i suppose to be switching between them for different sonar choices,ie;sidescan,2D, down scan or do i just leave it on the one setting for all?I am fishing in saltwater in a max depth of 35ft if this helps thanks in advance.
T.G
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: transducer select
« Reply #1 on: October 17, 2011, 05:48:20 AM »
I use HD Side Scan only. Gary
« Reply #2 on: October 17, 2011, 11:58:09 AM »
With the High Definition Side-Scan option, you
will have everything 2d, Side-Scan, DownScan.
The one you need to use should be the default
options for your unit.
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« Reply #3 on: October 17, 2011, 09:40:33 PM »
thanks guys , i will leave it in hi-def sidescan.
« Reply #4 on: October 18, 2011, 02:38:56 PM »
Hi-def sidescan  definately...
Last post August 24, 2010, 04:09:54 PM
Last post April 09, 2012, 09:59:55 AM
Last post April 09, 2012, 01:42:12 PM
by jbrady2852
Last post April 28, 2014, 08:54:37 AM
by rdico
Last post October 16, 2014, 08:11:22 AM
by Fly 1
Last post June 18, 2015, 08:47:37 AM
Last post August 27, 2015, 07:15:29 PM
by burgersb
Last post April 29, 2016, 03:03:55 AM
by Rpadar
