Author Topic: actual screen size  (Read 10945 times)
Offline gdvalley
actual screen size
« on: March 11, 2012, 09:27:39 PM »
I am looking at getting either the 587CI DI combo or the 596 C HD DI. I know the 587 has a 4.5 inch screen and the 596 has a 5 inch screen. What I am trying to find out is the actual dimensions of both screens. Any help would be greatly appreaciated.
Offline George
  • Software: Always up todate
Re: actual screen size
« Reply #1 on: March 12, 2012, 09:02:16 AM »
gdvalley
To calculate the screen size go to
--->  http://daleswanson.org/things/screensize.htm  <---
If I have done it right the 596 5 inch screen has an 4.3 Aspect Ratio which according to this program makes the dimensions 3" high x 4" wide, viewing area = 12".  The 587 4.5 inch screen with a 4.3 Aspect Ratio is 2.7" high x 3.6" wide, viewing area = 9.72"  The 596 is 23% larger.
You may want to go to a store and view the screen sizes, to make your decision.
George
« Last Edit: March 12, 2012, 09:08:17 AM by George »
Offline George
« Reply #2 on: March 12, 2012, 09:15:16 AM »
I just measured my 1197 10.4" screen and the Height 6.25 X Width 8.31". area = 51.94" which matches the program's calculations
George
« Reply #3 on: March 14, 2012, 02:10:03 PM »
gdvalley,
I have not measured the actual active areas of these unit’s displays but here are some measurements from other units that I believe use the same displays:
640 x 480 pixel display:
Height - 4.00 inches
Width - 3.00 inches
640 x 640 pixel display:
Height - 3.576 inches
Width - 3.576 inches
« Reply #4 on: March 14, 2012, 04:55:25 PM »
wow...surprising that .5 inch makes a difference in being able to see or not see..
Last post July 04, 2010, 01:31:49 AM
Last post December 21, 2011, 12:50:39 PM
by Double Digit
Last post January 07, 2011, 08:04:11 AM
by cdub
Last post June 16, 2011, 01:47:15 PM
Last post January 09, 2012, 08:30:31 AM
Last post May 30, 2013, 11:54:53 AM
by PaulB
Last post October 29, 2014, 11:20:37 PM
Last post December 14, 2017, 05:42:25 PM
by bigkahuna
