Author Topic: Utilities View Block Size  (Read 17941 times)
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
« on: October 28, 2014, 08:25:00 AM »
The size of the view block when using the utilities function to measure the length or to determine how tall an object is from its shadow is too small and cuts off some of the writing. Is this a bug or something I am doing wrong?? Anyone else having this problem? Using version 86.  ???
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
Re: Utilities View Block Size
« Reply #1 on: October 28, 2014, 08:55:59 AM »
here is image..............
« Last Edit: October 28, 2014, 08:57:23 AM by cache22 »
« Reply #2 on: October 28, 2014, 08:47:44 PM »
Mine is not doing that Curtis ...
I couldn't find anywhere in Humviewer an option to change font size ...
Is it possible that your monitor resolution is set to a size that is enlarging the font ...??
« Last Edit: October 28, 2014, 08:52:15 PM by rnvinc »
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
« Reply #3 on: October 28, 2014, 09:13:15 PM »
Your utility box looks entirely different, Rickie.  What Humviewer version are you using? I am also on windows 7.
« Reply #4 on: October 29, 2014, 07:49:55 AM »
I went into my monitor settings and changed the DPI from my default 90 to the other setting of 120 DPI ...
I get the same larger font as your OP ...
I think your issue is in the monitor settings and not a Humviewer issue ...
In Vista ... (I'm not sure in Windows 7)...
Right click on the desktop ...
Select "Personalize" ...
Select "Adjust font size (DPI)" ... (In the left column) ...
Change to a smaller DPI scale ...
But this will make all your font smaller ... Not just Humviewer ...
« Last Edit: October 29, 2014, 07:55:46 AM by rnvinc »
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
« Reply #5 on: October 29, 2014, 05:42:26 PM »
That's it...... Thanks Rickie.  Us septuagenarians need that larger font size!!   :(  ::)
« Reply #6 on: October 29, 2014, 09:49:58 PM »
I had to Google septuagenarian ... :)
I'm not far behind you ...
« Reply #7 on: October 29, 2014, 11:20:37 PM »
I'm a sexagenarian........maybe the first part of the word has to change after the age of 69...:)
Last post July 01, 2010, 12:39:23 PM
by vahntitrio
Last post June 16, 2011, 01:47:15 PM
Last post June 02, 2014, 04:01:40 PM
Last post January 14, 2012, 02:33:26 PM
by ecduzitgood
Last post February 25, 2013, 01:24:17 PM
by Ken L
Last post March 24, 2013, 04:58:03 PM
by Submaster
Last post February 19, 2014, 12:42:15 PM
Last post April 06, 2014, 02:51:31 PM
by LittleGazoo
