Author Topic: Helix SI image files, does screen size matter?  (Read 9406 times)
Offline bigkahuna
  • Accessories: Custom ROV with Imagenex sonar
« on: December 14, 2017, 06:59:58 AM »
I'm shopping for a SI sonar for mapping / SAR work in shallow water.  Did some homework and Humminbird's "mega" side imaging looks like the way to go.  I'll use ReefMaster to post process and view the depth and SI files after I've done the survey so I don't really need a big screen.  For use in ReefMaster, does it matter what size Helix display I get?  Or is the file resolution saved at the same size regardless of the display size?
Re: Helix SI image files, does screen size matter?
« Reply #1 on: December 14, 2017, 04:56:41 PM »
The raw data should be the same for the 9 and up.  The range you have set when recording SI will affect the data that is recorded.
Offline bigkahuna
« Reply #2 on: December 14, 2017, 05:42:25 PM »
Thanks Bob.  :)
Last post February 22, 2010, 10:13:30 AM
by mendota
Last post December 21, 2011, 12:50:39 PM
by Double Digit
Last post January 07, 2011, 08:04:11 AM
by cdub
Last post June 16, 2011, 01:47:15 PM
Last post March 14, 2012, 04:55:25 PM
Last post January 09, 2014, 08:07:12 AM
Last post December 31, 2014, 09:31:06 AM
Last post May 20, 2016, 10:56:27 AM
