Author Topic: Multiple Transducers on a single 898c SI  (Read 10873 times)
Offline DiemakerDave
  • Unit(s): 898c SI
  • Software: 6.180
« on: March 10, 2012, 11:47:34 AM »
Just want to make sure that what I'm planning on doing is going to work.
I don't think the side imaging transducer is going to see the other side past the outboard motor on my boat. The transducer is at least an 1" or 1-1/2' longer then the distance between the transom and outboard.
I'm thinking of putting a side imaging transducer on either side of the outboard with the AS-SI-L-R-Y  and a XP 9 20 inside the boat with the AS-SI-DB-Y and connecting it all together.
Your thoughts?
Dave
Re: Multiple Transducers on a single 898c SI
« Reply #1 on: March 10, 2012, 01:37:01 PM »
Sounds like you have done your homework..
all it takes is money... ;D
Seriously.  You do seem to have been looking around and getting ideas and in the right direction..
Chuck..
  • Unit(s): 898c SI
  • Software: 6.180
« Reply #2 on: March 10, 2012, 02:42:05 PM »
Thanks, when you live in Northern Ohio you have all winter to research and watch videos (and buy stuff)!
Offline Gattlin
« Reply #3 on: March 23, 2012, 12:13:59 PM »
Had had to use a couple small transom plates screwed together to get the transducer to clear the livewell intake. And it still wouldn't clear the lower unit, but the transducer does get reading on plane. But sense the SI doesn't work at high speed I just trim the lower unit out at trolling speed a touch and all is good. Hope this might help :)
Just one last cast.
Last post February 02, 2010, 10:23:36 PM
by soretoe
Last post February 10, 2010, 08:03:50 AM
Last post April 05, 2013, 07:40:40 PM
by raypla
Last post March 04, 2016, 10:48:22 AM
by Beaulieu80
Last post June 07, 2017, 11:25:19 PM
Last post June 02, 2020, 10:51:07 PM
Last post January 08, 2024, 07:28:00 PM
Last post May 12, 2025, 06:09:29 AM
by Kenai
