Author Topic: Mounting hdsi transducer on a skeeter  (Read 12335 times)
Offline fishnfool
  • Unit(s): 1197-997
  • Software: 6
  • Accessories: interlink weather
« on: April 15, 2016, 11:03:51 PM »
I put an 1197 on the dash of a 2002 2050 skeeter.The problem is the boat started to list to the lport side and the dealer thinks that it's the transducer doing it.if it is the problem i'm thinking of putting in a high speed ducer the problem then is where can i put the down and side transducer?? any thoughts wiill be appreciated
Offline fishreed
  • fishreed
  • Software: current
Re: Mounting hdsi transducer on a skeeter
« Reply #1 on: April 16, 2016, 03:02:12 AM »
Really?  do you know what boat or ship   "LIST" is?  Why would your boat "list" to port side? Do you have a heavy weight on the port side?  If you boat is "listing" to port side, it has nothing to do with a sonar transducer!
Offline fishnfool
  • Unit(s): 1197-997
  • Software: 6
« Reply #2 on: April 16, 2016, 06:49:48 PM »
I will say that the boat was leaning to the left or port side when under throttle
« Reply #3 on: April 16, 2016, 09:33:36 PM »
High performance hulls benefit from a shoot thru XP 9 20 (along with the AS SIDB Y cable) ...
Then mount the HDSI on the jackplate with an aftermarket bracket such as the Transducer Shield and Saver ...
http://www.transducershieldandsaver.com/
If there's no jackplate - mount the HDSI higher on the transom for low speed idle scanning ...
« Last Edit: April 16, 2016, 09:35:14 PM by rnvinc »
Offline fishnfool
  • Unit(s): 1197-997
  • Software: 6
« Reply #4 on: April 16, 2016, 10:09:41 PM »
Thanks rnvvinc I had only aluminum boats and never had a problem now with the setback i'm lost but with your help will get this on track much appreciated
Last post June 27, 2010, 12:04:16 AM
Last post February 02, 2012, 10:25:51 AM
Last post September 11, 2012, 05:01:42 PM
by Slinger
Last post March 26, 2013, 10:25:25 AM
Last post December 30, 2013, 10:52:41 PM
Last post March 12, 2015, 10:26:15 AM
by BrazosRiverTom
Last post February 08, 2019, 10:21:59 AM
by bassmasterG13
Last post February 17, 2026, 09:50:21 AM
by proskeeterman@comcast.net
