Author Topic: 787 problems  (Read 6243 times)
Offline rovaline
  • rovaline
  • Unit(s): 997 csi
  • Accessories: 5.840
787 problems
« on: January 13, 2012, 12:49:04 PM »
shortly after i turn on my unit it will turn off on its own so i have to keep turning it back on and sometimes it will make a funny noise and wont turn on
Offline George
  • Software: Always up todate
Re: 787 problems
« Reply #1 on: January 13, 2012, 02:42:44 PM »
rovaline
First make sure your battery is fully charged, my system use to shut down from low voltage.  The only thing on my battery was the starter motor for the outboard, but the battery was too small and after an hour would drain the battery to the point it shut down, since I purchased a larger battery I have not had the problem.
If you know that the battery is good, go through all of your connections to make sure everything is tight.  You may want to make a direction to the battery to rule out the in between wiring.
Hope you get it, it took me a while to determine my new battery was too small.  If you have the option to watch the voltage on the screen, turn it on, it may tell you the problem is low voltage.
George
« Last Edit: January 13, 2012, 02:44:20 PM by George »
Last post December 08, 2010, 06:28:53 PM
by Foster78
Last post January 16, 2011, 02:53:37 AM
by labboss2003
Last post March 18, 2011, 09:02:06 AM
by maxflia
Last post April 12, 2011, 09:49:52 PM
by bmann
Last post April 26, 2011, 06:41:14 PM
by TazzMan
Last post October 24, 2011, 01:19:20 PM
by ffmedic147
Last post January 17, 2012, 01:58:48 PM
Last post February 01, 2012, 05:10:49 PM
