Author Topic: 957 c transducer problems  (Read 7718 times)
Offline labboss2003
  • Unit(s): 957 c
  • Accessories: weather sense and cannon downrigger
« on: January 16, 2011, 02:32:08 AM »
Hello all,  new to site .My name is Bob.  I have a 957c, have had it for four years. In the past few months its developed a clicking sound where the transducer plugs into the back of the head unit. and the sonar runs very thin(bottom soundings)temp goes all over the place, I could  jiggle the connector around and it will fix the problem .Now i have to put a wedge in between the plug to keep the sonar and temp to read correctly. I have tried contact cleaner on both sides and elec. grease ,and still i have to wedge something in there to keep it working.
Do i need a new transducer or send it in for a new plug on the head unit or both?
Thanks for your time.
Re: 957 c transducer problems
« Reply #1 on: January 16, 2011, 02:45:31 AM »
Bob,
Welcome to the forum.
The Humminbird connectors have a tendency to lose contact sometimes.  Not sure about the clicking noise, but what I can recommend is to gently (very gently) bend the pins slightly outward.  This will help tighten the connection and make better contact.
If you have a cable collector for your unit, I highly recommend using it.  It will keep the connectors from wiggling around and loosening the connection.
Hope this helps,
Offline labboss2003
  • Unit(s): 957 c
« Reply #2 on: January 16, 2011, 02:53:37 AM »
Thanks............. did not think about bending the pins.
Last post June 27, 2010, 09:18:11 AM
by TazzMan
Last post April 12, 2011, 09:49:52 PM
by bmann
Last post April 26, 2011, 06:41:14 PM
by TazzMan
Last post July 01, 2011, 09:42:48 AM
by mchunter
Last post October 04, 2011, 07:11:29 AM
by Kenosha
Last post October 18, 2011, 06:03:51 PM
Last post March 14, 2013, 04:20:06 PM
Last post June 05, 2016, 11:18:04 PM
