Author Topic: SD Card Speed  (Read 7978 times)
Offline brettm4811
  • Unit(s): 898c si
SD Card Speed
« on: October 24, 2011, 08:55:35 PM »
Just wondering what speed the SDHC memory card needs to be to record on the 898c Si? Class 2 - 10? The higher the class the faster the card can read information. ( very important for HD camcorders )
Offline Rickard
Re: SD Card Speed
« Reply #1 on: October 25, 2011, 02:49:35 AM »
Hi,
There have been problems with some of the faster cards. Check this thread: http://forums.sideimagingsoft.com/index.php?topic=2884.0
Class 4 is enough for my 981.
Rickard
Offline Rüdiger
Re: SD Card Speed
« Reply #2 on: October 25, 2011, 09:29:07 AM »
Hi
I use the ScanDisk Extreme / 20MB/s / 4GB and its work very well.
mvh
Rüdiger
Finding is better than losing
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
Re: SD Card Speed
« Reply #3 on: October 28, 2011, 11:09:28 AM »
If you plan to do recordings get the SanDisk Extreme Class 10 card. The Write speed is what determines how well the card will work with your control head.  The faster it can be written to the faster the control head can clear it's buffer.  If the buffer gets full, recordings will stop until the buffer can be cleared by writing that data to the SDHC card.
And if you have a digital camera or plan to get one in the future and it uses an SDHC type card you can use the cards for both the camer and the Humminbird Unit.  I have several of the SanDisk Extreme 4 Gig and 8 Gig class ten cards that can write at 30 MB/sec
Regards,
Moose1am
Offline Rickard
Re: SD Card Speed
« Reply #4 on: October 28, 2011, 01:00:41 PM »
Yes, the faster cards should be better for any application, but I have tested speed class 10 and UHS-1 cards (30 and 45 MB/s) and these cards do not work properly with my unit. The result is data loss/gaps in the recordings which are difficult to detect if you don't expect them. This is probably caused by a software bug. The speed class 4 and 6 cards are fast enough and the recordings are (almost) perfect.
Rickard
Offline brettm4811
  • Unit(s): 898c si
Re: SD Card Speed
« Reply #5 on: October 29, 2011, 07:19:55 AM »
I have just bought a 4gb class 4 sdhc card. I will test is out next weekend and keep you posted.
Last post January 17, 2010, 12:31:04 AM
Last post March 04, 2011, 11:01:12 AM
by Moose1am
Last post May 28, 2011, 08:44:03 AM
by Del
Last post June 27, 2011, 05:38:49 PM
Last post July 14, 2011, 05:26:08 PM
Last post August 06, 2012, 02:41:57 PM
by ScottMN
