Author Topic: GPS NOT WORKING  (Read 17142 times)
Offline camo
  • Unit(s): matrix 37,797csi
GPS NOT WORKING
« on: October 01, 2011, 08:54:58 AM »
Hi there, New to the site and was hoping someone might be able to help.I have 2 HB units on my boat (797c2 with si&di upgrades and matrix 37).Both units now display 'no gps fix ',each has a seperate antenae and all connections are clean,haven't changed a thing so was hoping someone might have an idea what is going on
cheers camo
Offline George
  • Software: Always up todate
Re: GPS NOT WORKING
« Reply #1 on: October 01, 2011, 01:29:12 PM »
Hi Camo,
Welcome to this site.
You may want to give an overview of when the problem started, such as adding something to the system, the location of the units (are they exposed or under a canopy etc., voltage the units are getting, review what is working and what you think may have caused the issue.
We have some pretty good folks on this site, once they have an idea of the issue(s) they will add their thoughts, then others will state their opinions.
« Last Edit: November 16, 2011, 12:04:01 PM by George »
Offline camo
Re: GPS NOT WORKING
« Reply #2 on: October 01, 2011, 05:01:28 PM »
hi George
                 problem occured 2 nights ago ,got on the dam ,turned the 797 on, every function works except the gps ,checked the status and shows all is connected ,turned the unit off and let it sit then restarted thinking that it might not have started properly ,let it go while we heade across the dam giving it time to pick up satelites and still nothing 15mins later,so turned on the other unit a matrix 37 and same drama nothing all night,pulled up beside a mate and his 757 is working fine ,both units have seperate gps antenaes,both are exposed with no canopy ,voltage is fine,haven't changed any settings so it's got me stumped.
                 I remove the units and store them for travel and it has ben about a month since last use,other than that have tryed everything that i can think of other than sending the unit away
                  cheers camo
Offline Roddy
  • Scan,scan and rescan
Re: GPS NOT WORKING
« Reply #3 on: October 01, 2011, 11:07:29 PM »
Camo,
 Try cleaning the plugs both unit and gps wire plug.
 try checking pins in the plugs.
 I know the you said the batt is ok but make a old man happy and change it out with a fresh charged one.
 Check voltage at the power plug and what the unit is reading are the same.
 Dis gps ant wire and start unit give it five min to start up check gps status, should read no signal, then plug in gps ant watch gps status page. If it works good.
If it does not find someone  to test your units on there boat to see if it is the unit or the gps ant.
Go to the pub for a cold one mate!
Good luck Roddy
Scan,Scan and Rescan Roddy
Re: GPS NOT WORKING
« Reply #4 on: October 02, 2011, 09:07:29 AM »
What gps antenna are you using on each unit...
Offline camo
Re: GPS NOT WORKING
« Reply #5 on: November 16, 2011, 08:06:20 AM »
  It's a GR 16/4 external antennae
Re: GPS NOT WORKING
« Reply #6 on: November 16, 2011, 09:00:04 AM »
The 16 should work.  what does the system status screen show for connections...
Also how old is the unit(s)...
Offline camo
Re: GPS NOT WORKING
« Reply #7 on: November 16, 2011, 03:22:22 PM »
It shows connected for both units,so it's got me stumped.Both units work on my mates boat so i'm guessing the external anteneas have packed it in.just strange they both went at same time
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: GPS NOT WORKING
« Reply #8 on: November 16, 2011, 04:35:51 PM »
Have you tried each unit in each other's mount? Are they both standalone units? No interlink? Other than that check connections. Is are a way to manually test the gps pucks?
Offline George
Re: GPS NOT WORKING
« Reply #9 on: November 17, 2011, 11:37:19 AM »
Camo
Something is wrong in the way we are trying to understand the issue?  Not impossible but certainly improbable that both units are bad!  I think we are all missing something.
Some questions to generate some thoughts.
When did you install each unit?
How long did the GPS work on each?
Did anything occur right before you lost the GPS?
Is there someone or a dealer nearby to test your units on their system?
Can you take pictures of each unit and the proximity of the GPS receivers to them?
Can you shut down the sonar and just run the GPS?
Can you load the maps and see a boat showing your location?
What else is there?
Hang in there Camo, I am sure it someone will have the right information.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: GPS NOT WORKING
« Reply #10 on: November 17, 2011, 05:21:12 PM »
It shows connected for both units,so it's got me stumped.Both units work on my mates boat so i'm guessing the external antennas have packed it in.just strange they both went at same time
Camo are you outside in clear view of the satelites. That don't make sense loosing both antennas at the same time
must be a connection problem.   Gary
Re: GPS NOT WORKING
« Reply #11 on: November 17, 2011, 05:36:34 PM »
Camo, when you look at the system status screens you are saying it shows connected...when you look at the GPS diagnostic screen what level of gray bars (signal strength) does it show for (and how many) satelites are shown?
Does it show a position on the diagnostic screen..?
Is there a date time shown?
It is possible to have connection but not sufficient signal strength to work.
Blockage or bad antenna....could be the problem..
Or internal but you said the unit works on another boat...
We need more information and of course some pictures...
« Last Edit: November 17, 2011, 05:39:35 PM by sonar2000 »
Re: GPS NOT WORKING
« Reply #12 on: November 18, 2011, 12:25:58 PM »
Guys, it may sound improbable but I think both of his GPS Receivers went out at the same time as both units work on another boat.  What could have caused this is a mystery though…  ???
Re: GPS NOT WORKING
« Reply #13 on: November 18, 2011, 12:32:34 PM »
I would still like to see what the GPS diag screen shows...
If the signals are low then the puck(s) might be at issue..
Or if good levels then the unit...
Camo can you post on this...
« Last Edit: November 18, 2011, 12:34:41 PM by sonar2000 »
Last post April 21, 2010, 02:59:52 PM
by netman
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post March 23, 2012, 03:23:06 PM
by rheykoop
Last post April 04, 2012, 06:40:12 PM
Last post May 01, 2012, 08:12:43 AM
by ITGEEK
Last post May 13, 2012, 05:32:59 PM
by w2f4
Last post June 14, 2012, 07:01:39 PM
by ctf58
Last post June 24, 2012, 04:36:48 PM
by George
