Author Topic: working with the HM unit off the boat  (Read 6773 times)
Offline xcfranko
« on: June 24, 2012, 12:23:43 PM »
Hello,
First posting for me...hope the question is not too often repeated.
What is the best way to work with the unit off the boat?  How do I power it?  Any special settings?
Thanks in advance...
Offline George
  • Software: Always up todate
Re: working with the HM unit off the boat
« Reply #1 on: June 24, 2012, 04:36:48 PM »
xcfranko
A lot of us use a 110v power converter.
The converter that I have been using is from Digi-Key. it is made by CUI, Inc. Model HK-H1-A12, PRI - 100 -240V 50 - 60 Hz 0.8A SEC 12V=0 -2.5A (set at 2.0A).
This is the information on my converter which was recommended to me 3 years ago and I have been using it without any problems.
There are a lot of different converters used with success, you may want to search this site for them, they only thing I know is that amp output is important along with the voltage.
Make sure you use the recommended fuse (3 amps) on the power sides 3.
I also have a spare GPS and transducer that I use to play with the system.  Most of my updates are done in the house and I do go through the mapping programs in the house.
To view my recordings I use HumViewer and look at them on my computer.
George
Last post July 04, 2009, 12:00:48 PM
Last post October 10, 2012, 12:22:06 PM
Last post January 18, 2013, 07:56:42 AM
Last post September 14, 2014, 12:47:20 PM
by ttype86
Last post May 06, 2015, 01:21:16 PM
by KJ
