Author Topic: 898 and autopilot  (Read 9967 times)
Offline however11
  • Unit(s): 898c SI
  • Software: 4.880
  • Accessories: weather sensor
898 and autopilot
« on: September 24, 2011, 09:43:28 AM »
Hello
Is it possible to connect and drive an autopilot ghp10 garmin via nmea 183 from 898c used as a chartploter ?
Is it possible to input AIS signal from garmin VHF via nmea 183 into 898c ?
« Last Edit: September 24, 2011, 04:26:59 PM by however11 »
Offline Roddy
  • Scan,scan and rescan
Re: 898 and autopilot
« Reply #1 on: September 24, 2011, 10:10:11 PM »
However11,
Yes, A auto pilot and ASI DSI will work with a HB unit with EXT ANTENAE. EZ hook up. Roddy
Scan,Scan and Rescan Roddy
Offline however11
  • Unit(s): 898c SI
  • Software: 4.880
« Reply #2 on: September 25, 2011, 08:26:58 AM »
thanks
can you tell me more ?
does a tutorial exist ?
Offline Roddy
« Reply #3 on: September 25, 2011, 09:00:20 PM »
However11,
Don't know a tutorial.
This is a EZ hook up, the short pig tail on the HB GPS ANT goes to the ASI/DSC input/output on the radio.
I will make up a wiring diagram as soon as I can get out to my boat and post it to you. Roddy
Offline Roddy
« Reply #4 on: September 28, 2011, 07:19:23 PM »
However, Hope this helps. Roddy* Wiring Standard Horizon Chart plotter to Matrix AIS[1].pdf (243.41 kB - downloaded 1119 times.)
Last post April 20, 2012, 10:48:16 AM
Last post March 18, 2013, 09:03:57 AM
by Jim Jack
Last post August 23, 2013, 10:23:48 PM
by Chesapeake
Last post March 07, 2014, 02:07:06 PM
Last post May 15, 2014, 02:12:23 PM
by shsmith05088
Last post July 09, 2015, 10:41:13 AM
by sjefsrafsern
Last post July 15, 2016, 02:14:47 PM
by pat.gearhart@icloud.com
Last post August 19, 2020, 06:34:58 PM
