Author Topic: Raymarine s1000 autopilot and 998c SI  (Read 9465 times)
Offline choc_e
  • Unit(s): 997si
« on: April 18, 2012, 06:46:10 PM »
Just wondering if anyone has hooked up a 998c SI to a Raymarine S1000 autopilot via NMEA? Was it difficult and what wires do you connect?
I am looking at buying a Raymarine S1000, does anyone rate them? Or can anyone suggest another cheap autopilot for a twin engine cat with DF140s?
Ryan
Offline choc_e
  • Unit(s): 997si
Re: Raymarine s1000 autopilot and 998c SI
« Reply #1 on: April 19, 2012, 07:10:06 PM »
This is what the Raymarine autopilot says about NMEA connection.
Wire Colour   Pin   NMEA signal at s1000   Connection at 3rd Party GPS
Brown                    1   negative out                    NMEA --ve receive
Green                    2   positive out                    NMEA +ve receive
Orange                    3   positive in                    NMEA +ve transmit
Blue                    5   negative in                    NMEA --ve transmit
But the Humminbird NMEA connections read differently in the Humminbird manual:
The following NMEA sentences are output:
DPT - Depth
MTW - Water Temperature
GLL - Lat/Lon Position
GGA - GPS Fix Data
RMC - Recommended Minimum Specific GNSS Data
VTG - Course Over Ground and Ground Speed
ZDA - Time and Date
When navigating, the following NMEA sentences are also output:
APB - Autopilot Sentence B
BWR - Bearing and Distance to Waypoint
RMB - Recommended Minimum Navigation Info
Does this make sense to anyone?
« Reply #2 on: April 20, 2012, 10:48:16 AM »
The pins are the physical connections (cable) unit to unit.
The sentence is the data contained in the information between the units.
Last post January 20, 2010, 09:28:28 AM
Last post July 11, 2010, 07:07:17 AM
by dybvad417
Last post August 05, 2011, 04:25:21 AM
by goodwinexplorer
Last post September 28, 2011, 07:19:23 PM
by Roddy
Last post March 18, 2013, 09:03:57 AM
by Jim Jack
Last post August 23, 2013, 10:23:48 PM
by Chesapeake
Last post March 07, 2014, 02:07:06 PM
Last post May 15, 2014, 02:12:23 PM
by shsmith05088
