Author Topic: Humviewer Question - How do I transfer a waypoint to my unit?  (Read 11267 times)
Offline Double Digit
  • Unit(s): 998 c si...Navionics Platinum +
  • Software: 6.180
« on: September 05, 2011, 08:59:04 PM »
I was going over a recording i made this weekend with humviewer when i came across an object that i want too investagate next time i go out.I set a waypoint on the object i seen the waypoint on humviewer but when i put the SD card back in my unit the waypoint was nowhere to be found.So my question is if you make a waypoint using humviewer how do you get that waypoint in your unit so you can navigate to it when your on the water?
« Last Edit: September 05, 2011, 10:16:49 PM by RGecy »
Re: Humviewer Question - How do I transfer a waypoint to my unit?
« Reply #1 on: September 05, 2011, 10:18:18 PM »
Double Digit,
You will have to export the waypoint from Humviewer, import it into Humminbird PC, then export to your SD card.
Here is the topic and instructions in the Humviewer forum.  http://forums.sideimagingsoft.com/index.php?topic=667.0
Good Luck,
  • Software: 6.180
« Reply #2 on: September 06, 2011, 09:52:39 AM »
Sweet......Thanks for the info RGecy...... ;)
Last post July 02, 2011, 12:58:30 PM
by gofission
Last post April 12, 2012, 05:09:55 PM
Last post May 04, 2012, 03:30:50 PM
by bobby
Last post December 04, 2012, 10:58:24 AM
by whosmatt
Last post November 05, 2013, 12:02:52 AM
by CHOOhonets
Last post February 26, 2014, 03:21:15 PM
Last post June 21, 2016, 09:33:50 PM
