Author Topic: Waypoint transfer question (Humminbird PC->SD->Unit)  (Read 14081 times)
Offline CHOOhonets
  • Unit(s): 998 HD SI
  • Software: 6.49
  • Accessories: AS SI LR Y cable
« on: November 04, 2013, 04:16:25 PM »
Guys, your help needed:
For some reason I couldn't see any of my Humminbird PC waypoints after transferring them to SD card and putting it into the unit.
I have deleted all the waypoints from the unit and I have formatted the SD card after I downloaded all my waypoints to Humminbird PC. Then I uploaded information from the PC to the SD card.
Now all I can see on my SD card is a "matrix" folder with "DATA.HWR" file in it but no waypoints are available when I put my SD card in the unit and go to Nav->Waypoints and tracks (Simulation mode only since my GPS and transducer are on my boat and I am at mone with the head unit only).
Am I doing something wrong?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: Waypoint transfer question (Humminbird PC->SD->Unit)
« Reply #1 on: November 04, 2013, 08:57:32 PM »
First:
HB units can be booted into 2 Simulators without a transducer attached.
Point-of-Sale Simulator Mode is the default when you boot and let the boot continue.  Any changes made will be discarded when rebooted.
Full-Simulator Mode can be entered by pressing Menu-key on boot-screen and selecting Simulator.  Any changes will be retained.
You want to boot into Full-Simulator.
After your HB unit is booted into Full Simulator, then insert the SD-card with your waypoints.  You should be prompted to load Yes/No, select Yes.
The MATRIX folder on a SD-card can contain several files.
DATA.HWR file will contain all waypoints and routes. HWR--> Humminbird Waypoints Routes
nn.HT files will contain any HB Tracks. Each Track has its .HT file, 000.ht, 001.ht, ... nnn.ht
Be sure to insert your SD-card AFTER the HB unit is running.
Sometimes on problems it is easier if we know the software levels of you HB unit and HBPC. . .
« Last Edit: November 04, 2013, 08:58:58 PM by LittleGazoo »
Offline LittleGazoo
  • Software: 3.640
« Reply #2 on: November 04, 2013, 09:02:19 PM »
FYI.  Since you exported all your NAVDATA onto the SD-card, it was still there, so you could have just imported the waypoints back onto the unit.
Unless you were making HBPC changes.
And when I am uploading from HBPC  I almost always choose to Replace, not Add to a SD-card.
« Last Edit: November 04, 2013, 09:04:04 PM by LittleGazoo »
Offline CHOOhonets
  • Software: 6.49
« Reply #3 on: November 05, 2013, 12:02:52 AM »
Thanks you so much for such a detailed reply!
That was the reason:) Now everything works perfectly! Thank you!
Last post September 06, 2011, 09:52:39 AM
by Double Digit
Last post April 12, 2012, 05:09:55 PM
Last post June 14, 2012, 11:13:31 AM
Last post December 04, 2012, 10:58:24 AM
by whosmatt
Last post October 23, 2013, 08:29:29 AM
Last post February 26, 2014, 03:21:15 PM
Last post June 21, 2016, 09:33:50 PM
