Author Topic: Transferring waypoint out of Humviewer  (Read 18972 times)
« on: January 31, 2010, 08:41:13 AM »
I've figured out how to create a waypoint in Humviewer using the feature in the "Utilities" button...
How do I get that waypoint back into my Hummingbird unit...??
Offline terry0540
  • Unit(s): 798ci SI NVB
  • Software: 4.780
  • Accessories: none
Re: Transferring waypoint out of Humviewer
« Reply #1 on: February 01, 2010, 09:18:55 PM »
I am a new-bee and just started using the recording function. Found all the great features on humviewer and then created weighpoints my next step was to transfer back to the unit but I hit a wall.
Now I will be watching for replies to your post to get help. Now they know that there are more than 1 person that needs help with this issue.
Terry
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: February 02, 2010, 03:43:51 AM »
Hm,
took me a bit before I figured this out. But the search function and "export HumViewer" helped.
Here's what to do:
1. Go to the "File" tab in HumViewer and choose "export"
2. A pop up window opens, asking where to save what type of file.
3. Name the file (i.e. "Battleship BISMARCK" or whatever you've found) and choose "humminbird files (*gpx). Save it under "My_HumminbirdPC  in the "GPX_Files" Folder.
4. A pop up window will show asking "what to include in export". Uncheck / Check the apropriate check boxes and hit "OK" (at the bottom of the pop up window).  A pop up window will show up saying "data saved successfully".
Now the waypoint is saved in HumminbirdPC.
So far, so good.
5. Next open HumminbirdPC
6. Hit the "open file" icon in the tool bar on top of the HumminbirdPC screen.
7. Hit the File with your waypoint's name.
8. Hit "waypoints". Your waypoint will be shown. Now you can modify it with icons or rename it or whatever (in case it's not the "BISMARCK" you've found).
9. Now you can upload the waypoint either by using your card reader and your SD card or using the ASPC2 connection cable.
Voilá that's it. Hope it helps  ;)
Regards / Harry
« Last Edit: February 02, 2010, 04:35:33 AM by Jolly Roger »
YES,......
WE SCAN!
« Reply #3 on: February 02, 2010, 09:12:36 AM »
Thanks Jolly Roger...
I'll be saving your instructions in my HV file for future reference.......
Offline terry0540
  • Software: 4.780
  • Accessories: none
« Reply #4 on: February 02, 2010, 12:09:05 PM »
Thank you Harry
Your help is appreciated
Terry
Offline Jolly Roger
  • HB Addicted
« Reply #5 on: February 02, 2010, 12:28:52 PM »
No problem,
my pleasure at anytime.
Harry
YES,......
WE SCAN!
Offline gofission
  • Unit(s): PiranaMax 160, Matrix 37, 798ci HD SI
« Reply #6 on: July 02, 2011, 12:58:30 PM »
Ok, so i did all of the work to pick waypoints off the scan videos and change the icons. the files are on the SD chip. When I plug in the SD chip and turn on the HB, it says there is no new data and the waypoints dont transfer. There is no UPLOAD menu choice anywhere that I can find. What am I missing?
Last post August 16, 2011, 10:25:02 AM
by edwardpic
Last post September 06, 2011, 09:52:39 AM
by Double Digit
Last post April 20, 2012, 01:50:04 PM
Last post August 28, 2012, 03:18:03 PM
by Drifter
Last post July 11, 2014, 11:22:54 AM
by nwifishnut
Last post January 10, 2017, 07:44:34 PM
Last post March 04, 2020, 07:26:45 PM
by Fisherdan
Last post September 14, 2020, 11:02:49 PM
