Author Topic: Ethernet Questions  (Read 15166 times)
Offline survcat
  • Unit(s): 1198 and 898
Ethernet Questions
« on: February 28, 2011, 07:00:13 PM »
Do I need software 5.271 installed to make this happen? I have version 5.210 currently and I do not have the network tab. When is 5.271 going to be available?
Offline Billn
  • Unit(s): 898c si, 788ci combo
  • Software: 5.210
Re: Ethernet Questions
« Reply #1 on: March 02, 2011, 03:21:35 PM »
I have a 898c si and a 788ci Combo. Will the ethernet work in this combo?
Offline NITRO898
  • Unit(s): 1197C SI - 798ci si HD
  • Software: 5.500 5.590
  • Accessories: AS SI DB Y, ETHERNET & XP 9 20
« Reply #2 on: March 02, 2011, 09:09:36 PM »
Will my ethernet work now when I update my software for my 1197c si ? I want to hook up to 798c si hd. I have ethernet ready to go on 798 but not connected to the 1197c  Thanks, Earl
« Reply #3 on: March 03, 2011, 01:57:04 PM »
survcat,
Where did you get the software version 5.271 from?  The latest software I saw released was version 5.320 (for the 1197c Si) and it did not have the Ethernet capability with it.  So any new software that does would be a higher version number than 5.320
I do not know when the Ethernet software will be available.
« Reply #4 on: March 03, 2011, 02:29:42 PM »
But only if that is a 788ci HD DI Combo or 788ci HD Combo unit will it have the Ethernet connection and will work when they get the software done.
If it is not an “HD” version 788ci unit you will have to use an InterLink connection.
« Last Edit: March 03, 2011, 02:33:40 PM by Humminbird_Greg »
« Reply #5 on: March 03, 2011, 02:37:12 PM »
Earl,
The software that turns the Ethernet on has not been released as yet.  When it is you can update the software in each of your units (these will be separate software update files) and it should work.
Offline lucky14
  • Unit(s): 798C SI and 898C SI
  • Software: 5.210
« Reply #6 on: March 04, 2011, 10:41:47 PM »
I logged on to he HB site and see that a new version for the 798 and 898 is available (version 5.410).
However, I can't find a description of what changes.
Anyone know if this is the ethernet support we have been waiting for?
Offline lucky14
  • Software: 5.210
« Reply #7 on: March 04, 2011, 10:56:47 PM »
Well, I answered my own question.   ;D
The 798 download had no desciption, but the 898 download says:
"Description:
3/4/2011 12:00:00 AM - v5.410 Ethernet capabilities"
Offline lucky14
  • Software: 5.210
« Reply #8 on: March 06, 2011, 10:57:26 PM »
I got mine hooked up today and it appears to work as advertised on the boat.
Pretty simple to setup and use.
It does not appear to work in Demo Mode????
Offline jgollihar
  • Unit(s): 1197, 998
  • Accessories: interlink
« Reply #9 on: March 07, 2011, 09:34:03 AM »
Can you leave the Y-connector on, and still use the ethernet cable?
Offline survcat
« Reply #10 on: March 07, 2011, 09:37:12 AM »
The software version 5.21 is the one that both my 1198 and 898 came with. I have been watching for updates for them, but current version is the same as what I already have.
Offline survcat
« Reply #11 on: March 07, 2011, 10:08:37 AM »
I see today they have 5.410 out. Is this the ethernet capable version?
« Reply #12 on: March 07, 2011, 05:07:39 PM »
Yes you can leave the Y-cable on and still use Ethernet.
Yes the 5.410 software is the software that turns the Ethernet on.
Offline DaveW
« Reply #13 on: March 11, 2011, 12:29:54 AM »
Any word on what to do if you run three sounders?
I haveone on the bow, the 1197 on the console and am thinking about a second for the console prely for mapping.
Thoughts?
Offline Trytoofish
  • Software: 2.0, 7.51,
« Reply #14 on: March 11, 2011, 04:26:28 AM »
With Eithernet will you be able to run a split screen with 2 sonars sources. say bow and transom at the same time?
Try Too Fish  Forced To Work
« Reply #15 on: March 11, 2011, 08:28:08 AM »
Thoughts?
DaveW,
I don’t know anything about future expandability with the Ethernet connection, so I don’t know if you will one day be able to connect three or more units to an Ethernet hub or anything like that.
« Reply #16 on: March 11, 2011, 08:31:51 AM »
No, not right now at least.  I don’t know what they are thinking about for future Ethernet functions and capabilities, but if this is something that you would like I would add it to the Wish List.  For now you can only use the sonar data from the second unit and transducer while ignoring the sonar from the transducer the unit is connected to – and not a combination of both.
Offline thadraperyfallz
  • Unit(s): 550, 565, 798ci
  • Software: 5.210
  • Accessories: n/a
« Reply #17 on: March 29, 2011, 11:26:46 PM »
I have a 2010 model 798ci (not the hd model).  I am looking to get an 898.  Is there some type of adapter for the 798 that I can I connect them with ethernet?
I didn't see anything in here that specifically called out this model.
Thanks!
« Reply #18 on: March 31, 2011, 03:26:07 PM »
No there is not and there won’t be anything in the future either.  Being able to use an Ethernet connection includes having the circuitry on the PCB as well as having the external connection and software.  This added circuitry (in fact a whole new PCB) was a part of the unseen changes from the older 798ci Si and 798c Si units to the newer 798ci HD Si units.
Offline Fishton
  • FishTec
    • FishTec - Sonar and Mapping Solutions
  • Unit(s): 1197cxSI
« Reply #19 on: June 11, 2011, 03:04:05 AM »
I have a 1197cxSI connected to a 788 HD DI.
Why do I not get the TRUE DI view option from the 788 on the 1197?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #20 on: June 12, 2011, 05:16:22 PM »
ok
« Last Edit: June 12, 2011, 06:59:47 PM by stillbear »
Offline Fishton
  • FishTec
  • Unit(s): 1197cxSI
« Reply #21 on: June 13, 2011, 12:40:59 AM »
ok?
« Reply #22 on: June 13, 2011, 12:50:33 PM »
I’ll agree to: ok
(now, what did I just agree too?)
The DI sonar is not sharable through the Ethernet connection.  I know someone who said that they would look into this but my guess is the 1197 does not have the programming for the single element DI sonar or “TRUE DI” sonar as you call it.
Offline Fishton
  • FishTec
  • Unit(s): 1197cxSI
« Reply #23 on: June 13, 2011, 01:43:00 PM »
Hi Greg,
True DI, or single element DI as you call it, has become as important to my fishing as SI was to conventional 200kHz sonar when it was first introduced.
More and more anglers around the world that fish in the 10 - 180ft range are realizing this every day.
Last post February 09, 2011, 06:58:53 AM
by FuzzyGrub
Last post March 13, 2011, 10:08:16 AM
by Trytoofish
Last post March 16, 2011, 07:45:38 PM
by Trytoofish
Last post March 18, 2011, 03:21:13 PM
Last post June 27, 2011, 11:23:29 PM
by RzorbackAngler
Last post May 17, 2014, 11:58:48 PM
by sfw1960
Last post August 10, 2014, 11:08:10 PM
Last post October 19, 2014, 08:57:00 PM
