Author Topic: 899 general questions  (Read 14768 times)
Offline jvm1
  • Unit(s): 899
« on: May 14, 2014, 08:56:15 AM »
Well finally was able to put the boat in the water and test the unit.
Worked good I think. The lake I was one suffered a tremendous kill since fall and I didn't graph many things but everything seemed to be running good.
I do have a couple general questions,
Is it normal to loose bottom at higher speeds with just the HD transducer?
I also get a roster tail from the transducer so maybe I installed it too low/high?
I can post a pic later if necessary.
Also, what normal settings do you guys prefer for your contrast, sensitivity etc?
Offline Airliner9
  • Unit(s): 899CI HD SI
Re: 899 general questions
« Reply #1 on: May 14, 2014, 09:42:47 AM »
Hello!  I just got my 899 in the water early this month and I'm pretty happy with it so far.  I've got mine mounted on a Lund Rebel XL and must have got lucky with the transducer mount.  No rooster tail and the sonar image is stable at full speed (only 31 MPH, no speed demon, but good enough for me  ;D).  Think you will need to play with your mounting position a little bit.  Think it would be best to try the easy stuff first and adjust the angle.  If you're throwing a rooster tail it shows you've got some serious turbulence around the transducer at speed, which of course will effect your readings.
« Reply #2 on: May 14, 2014, 02:54:02 PM »
A roostertail from the transducer can mean that the transducer is too low.  However on some boats the transducer has to mounted very low to get a reading at higher speeds.
Is this the larger HDSi transducer or the standard Compact Side Imaging (CSi) that comes with the 899ci HD Si unit?  If it is the CSi transducer, then there is a roostertail plug that came with it.  Make sure that it is installed.  The HDSi transducer does not have such a plug.
Offline jvm1
  • Unit(s): 899
« Reply #3 on: May 14, 2014, 03:46:59 PM »
It's the HDSI transducer, I will post a pic later today. I lose bottom as soon as I go over 7 mph. the read is just 1.6 feet from 7 to 25 mph.
I'm still getting used to the sonar as well, I have it set to auto adjust and it seems like only half the screen is used, the rest is showing bottom.
Offline jvm1
  • Unit(s): 899
« Reply #4 on: May 16, 2014, 02:20:14 PM »
Here is a pic, not the best but i'm not at home and my wife had problems finding the transducer  ;D
« Reply #5 on: May 16, 2014, 02:51:43 PM »
Hard to tell a whole lot about the transducer from that picture.  We really need to see one from straight behind and one from the side with both at the height of the bottom of the transducer.  Need to see under the hull forwards of the transducer too.
Demanding, aren't we?
Offline jvm1
  • Unit(s): 899
« Reply #6 on: May 16, 2014, 03:02:21 PM »
here are a few more
« Reply #7 on: May 16, 2014, 03:57:26 PM »
From the pictures it looks like the transducer would need to go lower but that contradicts the roostertail spray.  Maybe try it a little lower and see if it improves or not.  Getting transducers to work at high boat speeds can be very tedious with lots of small adjustments and quick trips on the water in between.
Offline jvm1
  • Unit(s): 899
« Reply #8 on: May 16, 2014, 04:09:45 PM »
I'll drop it down some, could it be the cable that is messing things up? the rooster tail kind off goes sideways and hits the outboard.
I'm going on a week long trip next week and would really like this working. Should have paid for the install I guess.
« Reply #9 on: May 16, 2014, 04:17:11 PM »
I doubt the cable is doing it jvm1.  It is just going to take some adjusting and testing is all to get it to read as well as it can on your boat.  Aluminum boats are usually tricky.
« Reply #10 on: May 16, 2014, 09:35:37 PM »
I have seen some fabricated deflector shields mounted above the HDSI to knock the rooster tail down...
It could be made from heavier gauge aluminum flashing in a configuration that mounts between the transom and the HDSI bracket...and then creates a kinda "hood" over the HDSI...
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #11 on: May 17, 2014, 07:15:48 PM »
Works good too - huh Rickie??  ;)
« Reply #12 on: May 17, 2014, 11:48:41 PM »
From the reports I've heard...the home made deflector does work well...
I don't have an HDSI on the transom...so I'm just deferring to reports I've read...
(You can see my HDSI in my avatar...along with a few other xducers on da'ducer apparatus®)...
Offline sfw1960
« Reply #13 on: May 17, 2014, 11:58:48 PM »
Been to your site Rickie - I ran a CSi XDCR without a roostertail plug before...LOL WOW! You could keep cool in the summer....
I have seen pics of the deflectors & they do work.... my rig is a tin Deep V so I have a big splash well and you usually don't get a lot of spray when installed properly. I was thinking if I wanted a second XDCR at the front I would fab something like your "apparatus" but two SI machines networked give me options 0' plenty.
RAS
« Last Edit: May 18, 2014, 12:01:21 AM by sfw1960 »
Last post April 08, 2010, 08:08:07 AM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post May 13, 2010, 02:17:50 PM
by RzorbackAngler
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post November 08, 2011, 12:56:58 PM
Last post January 22, 2013, 04:16:17 AM
by Rüdiger
Last post March 28, 2013, 10:10:24 AM
by Triton Anlger
Last post May 11, 2013, 11:29:14 PM
by KAG
