Author Topic: 798SI works perfectly with trim tab mounted transducer..now for fish??  (Read 13762 times)
Offline lolar3288
  • Unit(s): 798ci
Just got back for cruising for over a month....mostly Lake Ontario and the Thousand Islands right up to Brockville.
I used the sidescan/ depth view throughout the Thousand Islands and it was impressive how well it displayed bottom on the side  scan and was very useful in confirming channels and rocks.  I don't have much experience setting side scan up but for the most part it was simple.
As a straight fish finder it was also excellent (found bait, surface bait and fish getting one salmon over 20 pounds) and I do have a lot of experience with good quality fish finders but this is my first Humminbird.  It is truly one of the best units I have even used and I date right back to paper graphs!
Only thing I have not been able to master is side scanning for fish suspended above bottom and near the surface.  I am playing with the gain, etc but still either don't have the right combination of settings or the skill reading the graph.
All in all, as per my other posts, the transducer mounted on the trim tab worked out great.
Larry
Re: 798SI works perfectly with trim tab mounted transducer..now for fish??
« Reply #1 on: August 08, 2011, 10:26:32 AM »
Larry,
Glad the trim tab mounted Si transducer works well for you.  I like to turn up the Sharpness menu to see fish.  Give it a try at different settings and see how you like it.
Offline lolar3288
  • Unit(s): 798ci
« Reply #2 on: September 07, 2011, 10:23:25 AM »
I have played a little more with the side scan and I get good bottom image but still struggling with the fish thing.
It would have been useful if Humminbird put a full scale on the side scan.  It is a very small image to start with so a scale would help.
Offline Wingnutt
  • Unit(s): 798CI HD SI
« Reply #3 on: September 07, 2011, 12:27:55 PM »
It takes some practice to display fish.  Different water conditions & fish require different sensitivities on any given day.  Experimenting is really the only way to learn.
As for the scale, you can put range lines on the side imaging:
Menu-> Menu->Sonar tab-> Si Range lines.
It will divide the area into 4 equidistant sections with a distance for each.
I think that's what you are referring to but I could be wrong.
Offline lolar3288
  • Unit(s): 798ci
« Reply #4 on: September 12, 2011, 12:43:36 PM »
Yes, thanks, that is what I was referring to.  Must have missed that in the manual!
Larry
Last post December 19, 2009, 10:13:47 PM
by capttim
Last post March 10, 2010, 12:54:59 PM
Last post March 16, 2010, 10:16:16 AM
Last post December 20, 2010, 01:59:36 PM
by Kimi
Last post May 22, 2011, 09:55:36 AM
by lolar3288
Last post April 27, 2012, 09:50:51 AM
by steelebob
Last post November 06, 2015, 05:55:18 AM
by skeeter08
Last post July 04, 2019, 04:20:34 AM
by fishreed
