Author Topic: Paint on transducer Thru Hull / fixed mounted ?  (Read 13403 times)
Offline Eksnipan
  • Unit(s): Onix 10 SI 797c2 SI
  • Software: 4.770
  • Accessories: XPTH 9 HDSI 180 T Plastic Thru Hull
« on: March 14, 2010, 05:16:02 AM »
Is it a problem to use bottom paint on a thru hull SI Transducer ?
XPTH 9 HDSI 180 T
BR Eksnipan
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Paint on transducer Thru Hull / fixed mounted ?
« Reply #1 on: March 14, 2010, 09:30:38 AM »
Jan,
it is not recommended to paint the transducer.
Regards / Harry
YES,......
WE SCAN!
Offline keizerh
  • Unit(s): none
« Reply #2 on: March 14, 2010, 05:05:49 PM »
you can put a sign in it
Forbidden for Barnacles
I would paint it or use propshield
hendrik
« Reply #3 on: March 16, 2010, 10:16:16 AM »
It’s not recommended to use paint on the plastic transducers.  If you still want to please follow these two rules: don’t use anything that has metal in it, and don’t paint it in a manner that will leave air bubbles in the paint.  Both of these will block some of the sonar signal and lead to weak or no readings.
Oh, just thought of a third: don’t use anything that will attack the plastic.
Last post March 10, 2010, 12:54:59 PM
Last post March 31, 2010, 10:53:54 PM
by diver651
Last post April 14, 2010, 02:45:32 PM
Last post March 04, 2012, 05:07:34 PM
by Fay
Last post March 13, 2011, 05:47:57 PM
by lolar3288
Last post September 12, 2011, 12:43:36 PM
by lolar3288
Last post December 20, 2012, 11:47:32 AM
by Fay
Last post April 27, 2012, 09:50:51 AM
by steelebob
