Author Topic: Mounted transducer on trim tab..we will see!  (Read 14253 times)
Offline lolar3288
  • Unit(s): 798ci
« on: May 12, 2011, 10:07:20 AM »
I ended up mounting my transducer on the trim tab beside the current one for my lower bridge fish finder.  Of course I can't run both at the same time but that is not an issue.  It was the only clear spot I could get.  It works at the dock....we will see what happens when I move!  The boat is a low speed boat to begin with.  I usually fish at 2.4 to 2.6 knots and cruise at around 8.
I do wish humminbird was more clear on what usually comes with a unit and what is clearly an option.
I assume the standard transducer with the 798cx si is not the Quad.
Now comes learning how to use the unit!
ila_renderedila_renderedila_renderedila_rendered
« Last Edit: May 13, 2011, 03:51:26 PM by lolar3288 »
Offline Roddy
  • Scan,scan and rescan
Re: Mounted transducer on trim tab..we will see!
« Reply #1 on: May 12, 2011, 10:32:38 AM »
Lolrr,  Can you post a shot of the whole stern. Roddy
Scan,Scan and Rescan Roddy
« Reply #2 on: May 12, 2011, 11:25:59 AM »
I don't know if you realize this, but you have the same picture shown four times.
« Reply #3 on: May 12, 2011, 04:29:13 PM »
lolar3288,
The standard transducer for all 798 units (cx or other models) is the XNT-9-Si-180-T transducer.  Why do you think you have a QuadraBeam transducer?
Offline lolar3288
  • Unit(s): 798ci
« Reply #4 on: May 13, 2011, 03:46:35 PM »
I didn't think I had the Quad ....but there is no where in the box or manual that states the name and number of the standard transducer, just that the Quald is optional....the manual doesn't do a good job in stating the specifics of all the units it covers in my opinion.
Sorry about the pictures....I had separate photos but something got screw up in the down loading.  When I clicked on more attachments it didn't actually give me them, just a repeat of two.
Offline lolar3288
  • Unit(s): 798ci
« Reply #5 on: May 13, 2011, 03:53:54 PM »
I fixed up the pictures.  You can see the side view of the whole stern.
Offline lolar3288
  • Unit(s): 798ci
« Reply #6 on: May 22, 2011, 09:55:36 AM »
We tested this setup today and it seems to work well.  Straight down fish finding work fine up to 7 knots and  maybe faster as we did not go above 7 knots.
Side scan from 2 up to 6 knots again seems to work fine but I need more time to figure out how to set up the side scan, which colours work best, etc.  We did get responses and I could see the hull when passing a docked freighter.  I will start a new post on side scan settings to  learn more in regard to setting it up but the transducer placement seems to be ok. ;D
Last post March 10, 2010, 12:54:59 PM
Last post March 16, 2010, 10:16:16 AM
Last post September 12, 2011, 12:43:36 PM
by lolar3288
Last post April 27, 2012, 09:50:51 AM
by steelebob
Last post May 06, 2015, 05:20:22 PM
Last post May 14, 2015, 12:58:38 PM
by wconn1979
Last post May 13, 2015, 10:25:56 PM
by wconn1979
Last post November 06, 2015, 05:55:18 AM
by skeeter08
