Author Topic: dr depth via 1197  (Read 7041 times)
Offline goodwinexplorer
  • Software: 4.18
dr depth via 1197
« on: August 05, 2011, 04:32:01 AM »
1197 has any one connected this unit to a pc and run dr depth in real time?
what leads? where can i get them
bob
Re: dr depth via 1197
« Reply #1 on: August 05, 2011, 02:38:19 PM »
I created a new post that answers your question here: http://forums.sideimagingsoft.com/index.php?topic=2896.msg16497#msg16497
Offline Rüdiger
« Reply #2 on: August 06, 2011, 04:01:44 AM »
Yesterday i tested the ethernetfunction together with DrDepth.
Absolutely magnificent !!
I think this live-sidescan-mosaik funtion is a „revolution“ for wreckhunters. Now it is possible to effectively scan the search area without white spots.
mvh
Rüdiger
Finding is better than losing
  • Software: 4.18
« Reply #3 on: August 07, 2011, 09:41:58 AM »
thanks  for the info i will order a cable tomorrow, there area few ethernet cables availabel which one?
bob
Offline Rüdiger
« Reply #4 on: August 07, 2011, 01:11:35 PM »
orange-white = 1
orange = 2
green-white = 3
green = 6
That's the inkcoverage of my cable, but i do not know as all HB-ethernetcable are equal.
mvh
Rüdiger
Offline Mark1000
  • Unit(s): 1197c SI
  • Software: 5.500
  • Accessories: GPS antenna
« Reply #5 on: August 07, 2011, 11:14:33 PM »
Thanks Rudiger, are there any other tips you can give us to help get ethernet connection working to Dr. Depth.   I followed the Dr. Depth instructions - spliced a RJ45 connector onto humminbird ethernet cable AS EC 10E.  Checked it for continuity with an ohm meter to make sure cable was ok.   Changed the settings in Dr. Depth to look for HB ethernet.  Windows firewall turned off.    Dr Depth either gives me an error message (says something like not able to establish Humminbird ethernet connection) or else just sits there waiting for gps position which never comes.  Did you check "no NMEA" in Dr. Depth NMEA/COM settings?  Did you have the HB NMEA output turned off (I tried it both ways)?   Did you have to change any LAN setting on your laptop?   Any information will probably help the rest of us.
Offline Rüdiger
« Reply #6 on: August 08, 2011, 03:32:07 AM »
Hey Mark
In the networksettings turn the local network on,in the firewallsetting you must allow DrDepth the networkconnection, then follow the DrDept helpinstruction in all points and it must work.
I use -no NMEA-
good luck
Rüdger
-- I use Windows XP --
« Last Edit: August 08, 2011, 03:36:52 AM by Rüdiger »
Last post October 27, 2009, 02:45:33 PM
Last post March 29, 2010, 01:17:11 PM
Last post April 06, 2010, 03:38:06 PM
by Chiboo
Last post May 18, 2010, 12:29:28 PM
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post April 22, 2011, 11:04:47 AM
by Roddy
Last post June 19, 2015, 08:53:46 AM
Last post May 26, 2019, 10:29:30 PM
