Author Topic: Unit cuts out...  (Read 5780 times)
Offline jimcopp
  • Work always gets in the way of fishing
  • Unit(s): 898
Unit cuts out...
« on: June 29, 2011, 05:02:14 AM »
I've had my 898si for almost a year now and it's worked flawlessly in rough water the entire time, until recently. It's been cutting out on big waves or any kind of jolt to the boat.
After it cuts out, it will fire back up and work just fine until the next big jolt. I've checked the wires and all connections are sound.
I'm a new poster to this forum and I understand if no-one wants to offer any suggestions. I can offer a bunch of Central Illinois help in return; I just want to know whats wrong with my unit and get it to work like it did before.
Thanks.
185 Lowe
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Unit cuts out...
« Reply #1 on: June 29, 2011, 09:14:29 AM »
Thanks.
185 Lowe
    Jim take your power plug from the head gently spread the two pins apart should fix your issue. Gary
Offline ETnSC
  • Unit(s): 1197c SI
  • Software: 5.43
« Reply #2 on: June 29, 2011, 10:56:16 AM »
ET
Offline edwardpic
  • Just fish....No excuses
    • My Company
  • Unit(s): 898c and 1198c
  • Software: 5.500 and 5.500
« Reply #3 on: June 29, 2011, 12:59:16 PM »
The power connections on the HB units are kinds cheap. I dont think they are made very secure and can become loose over time. I had this happen once during a big storm here in Florida, but only once. I would love to see better water tight connections in the future like Amphenol connections but thats a dream. Definately check the pins on the power side of the connector, there has been issues mentioned by others on this forum.
Big E
Offline jimcopp
  • Unit(s): 898
« Reply #4 on: July 02, 2011, 12:59:07 PM »
Thank you for the responses. I will try the recommendations and let you know how it works.
Thank again!!
Offline chet
  • Unit(s): 898c si
  • Software: latest
  • Accessories: none
« Reply #5 on: July 03, 2011, 10:29:31 AM »
HI jim i had the same problem with mine and tried everything, kept doing the same thing. You will probably have to send the unit in for repair. I tested mine out yesterday out on the ocean with no problems. Hope this helps. ;D
Offline Roddy
  • Scan,scan and rescan
« Reply #6 on: July 03, 2011, 10:41:12 PM »
I have used a tooih pic onthe power plug. Roddy
Scan,Scan and Rescan Roddy
Last post March 28, 2010, 10:03:40 PM
Last post June 06, 2010, 07:37:56 PM
by fishmanmike
Last post January 11, 2011, 09:24:13 AM
Last post July 18, 2011, 03:52:09 PM
Last post November 22, 2011, 11:02:08 AM
Last post January 16, 2012, 01:20:22 PM
Last post August 31, 2012, 04:34:01 AM
by Rüdiger
